#If VBA7 Then
Private Declare PtrSafe Function DeleteFile Lib "kernel32" Alias "DeleteFileA" (ByVal lpFileName As String) As Long
Private Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As LongPtr, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As LongPtr
#Else
Private Declare Function DeleteFile Lib "kernel32" Alias "DeleteFileA" (ByVal lpFileName As String) As Long
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
#End If
Private Sub PrintEmailBodyAndAttachments()
Dim objMail As Outlook.MailItem
Dim objSel As Outlook.Selection
Dim objAtt As Outlook.Attachment
Dim i As LongPtr, j As LongPtr, lngNumAtt As LongPtr
Dim strAttFilePath As String
i = 1
SetDefaultPrinter "Tên máy in"
Set objSel = Application.ActiveExplorer.Selection
For i = 1 To objSel.Count
If TypeOf objSel.Item(i) Is Outlook.MailItem Then
Set objMail = objSel.Item(i)
With objMail
.PrintOut
If .Attachments.Count > 0 Then
For j = 1 To .Attachments.Count
Set objAtt = .Attachments.Item(j)
strAttFilePath = Environ$("TEMP") & "\" & objAtt.FileName
objAtt.SaveAsFile strAttFilePath
Select Case GetFileExtension(strAttFilePath)
Case ".xls", ".xlsm", ".xlsb", ".xlsx", ".doc", ".docx", ".docm", ".pdf"
ShellExecute 0, "print", strAttFilePath, vbNullString, vbNullString, 0
End Select
DeleteFile strAttFilePath
Set objMail = Nothing
Set objSel = Nothing
Set objAtt = Nothing
Private Sub SetDefaultPrinter(PrinterName As String, Optional ComputerName As String = ".")
Dim Printer As Object, Printers As Object, WMIService As Object
Set WMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & ComputerName & "\root\cimv2")
Set Printers = WMIService.ExecQuery("Select * from Win32_Printer Where Name = '" & PrinterName & "'")
For Each Printer In Printers
Printer.SetDefaultPrinter
Set Printer = Nothing
Set Printers = Nothing
Set WMIService = Nothing
Private Function GetFileExtension(FileName As String) As String
GetFileExtension = Mid(FileName, InStrRev(FileName, "."))
If Err.Number = 5 Then
GetFileExtension = vbNullString
Vừa chen ngang, vừa không đúng chủ đề.bạn giải giùm mình bài này với. Dùng hàm gì để đếm số hành khách ở cột nơi đến ra cột số hành khách/chuyến. Như dòng đầu có 4 hành khách. Ngăn cách giữa các hành khách là dấu +
Có nhiều cách viết code VBA trong trường hợp này, ở đây tôi xin trình bày một cách như sau (giả sử tệp đính kèm chỉ bao gồm phần mở rộng ".xls", ".xlsm", ".xlsb", ".xlsx", ".doc", ".docx", ".docm", ".pdf":
Chọn những thư cần in trong Outlook.
Mã:Option Explicit #If VBA7 Then Private Declare PtrSafe Function DeleteFile Lib "kernel32" Alias "DeleteFileA" (ByVal lpFileName As String) As Long Private Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As LongPtr, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As LongPtr #Else Private Declare Function DeleteFile Lib "kernel32" Alias "DeleteFileA" (ByVal lpFileName As String) As Long Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long #End If Private Sub PrintEmailBodyAndAttachments() Dim objMail As Outlook.MailItem Dim objSel As Outlook.Selection Dim objAtt As Outlook.Attachment Dim i As LongPtr, j As LongPtr, lngNumAtt As LongPtr Dim strAttFilePath As String i = 1 SetDefaultPrinter "Tên máy in" Set objSel = Application.ActiveExplorer.Selection For i = 1 To objSel.Count If TypeOf objSel.Item(i) Is Outlook.MailItem Then Set objMail = objSel.Item(i) With objMail .PrintOut If .Attachments.Count > 0 Then For j = 1 To .Attachments.Count Set objAtt = .Attachments.Item(j) strAttFilePath = Environ$("TEMP") & "\" & objAtt.FileName objAtt.SaveAsFile strAttFilePath Select Case GetFileExtension(strAttFilePath) Case ".xls", ".xlsm", ".xlsb", ".xlsx", ".doc", ".docx", ".docm", ".pdf" ShellExecute 0, "print", strAttFilePath, vbNullString, vbNullString, 0 End Select DeleteFile strAttFilePath Next End If End With End If Next Set objMail = Nothing Set objSel = Nothing Set objAtt = Nothing End Sub Private Sub SetDefaultPrinter(PrinterName As String, Optional ComputerName As String = ".") Dim Printer As Object, Printers As Object, WMIService As Object Set WMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & ComputerName & "\root\cimv2") Set Printers = WMIService.ExecQuery("Select * from Win32_Printer Where Name = '" & PrinterName & "'") For Each Printer In Printers Printer.SetDefaultPrinter Next Set Printer = Nothing Set Printers = Nothing Set WMIService = Nothing End Sub Private Function GetFileExtension(FileName As String) As String On Error Resume Next GetFileExtension = Mid(FileName, InStrRev(FileName, ".")) If Err.Number = 5 Then GetFileExtension = vbNullString End If End Function
Đặt code dưới đây vào Module trong trình soạn thảo VBE của Outlook (nhớ kích hoạt tab Developer):Có cách nào lấy toàn bộ file đính kèm từ 1 địa chỉ mail gửi đến không bạn.
Nếu được nhờ bạn hướng dẫn giúp.
Public Sub DownloadAttachments(SenderEmailAddress As String)
Dim objFSO As Object
Dim strRCDatePath As String, strFolderPath As String, strSenderPath As String
Dim i As Long, j As Long
Dim strFilter As String, strSenderEmailAddress As String
Dim colItems As Outlook.Items
Dim objInbox As Outlook.Folder
Set objFSO = CreateObject("Scripting.FileSystemObject")
strFolderPath = Environ$("USERPROFILE") & "\Documents\OutlookAttachments\" 'Thu muc luu tap tin dinh kem, mac dinh: C:\<nguoidung>
If Not objFSO.FolderExists(strFolderPath) Then objFSO.CreateFolder strFolderPath
Const PR_SENDER_EMAIL_ADDRESS As String = "http://schemas.microsoft.com/mapi/proptag/0x0C1F001F"
Const PR_HASATTACH As String = "http://schemas.microsoft.com/mapi/proptag/0x0E1B000B"
strSenderEmailAddress = SenderEmailAddress 'Dia chi email nguoi gui
strFilter = "@SQL=" & Quote(PR_SENDER_EMAIL_ADDRESS) & " = '" & strSenderEmailAddress & "' AND " & Quote(PR_HASATTACH) & "=1"
Set objInbox = Application.Session.GetDefaultFolder(olFolderInbox)
Set colItems = objInbox.Items.Restrict(strFilter)
For j = 1 To colItems.Count
Set objMail = colItems.Item(j)
With objMail
If Not objFSO.FolderExists(strFolderPath & GetDateFromReceivedTime(.ReceivedTime)) Then
strRCDatePath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime)
objFSO.CreateFolder strRCDatePath
Else: strRCDatePath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime)
If Not objFSO.FolderExists(strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName) Then
strSenderPath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName
objFSO.CreateFolder strSenderPath
Else: strSenderPath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName
For i = 1 To .Attachments.Count
Set objAtt = .Attachments.Item(i)
If objFSO.FileExists(strSenderPath & "\" & objAtt.filename) Then
objFSO.DeleteFile strSenderPath & "\" & objAtt.filename
objAtt.SaveAsFile strSenderPath & "\" & objAtt.filename
Shell "explorer """ & strFolderPath & "", vbNormalFocus
Private Function Quote(Text As String) As String
Quote = Chr(34) & Text & Chr(34)
Private Function GetDateFromReceivedTime(ReceivedDateString As String) As String
Dim RDString As String
RDString = Trim(Format(Left(ReceivedDateString, InStr(ReceivedDateString, " ")), "dd-mm-yyyy"))
GetDateFromReceivedTime = RDString
Private Sub Test()
Call DownloadAttachments("abc@gmail.com")
Thật tuyệt vời, những dòng code của anh chạy cực nhanh và chính xác.Đặt code dưới đây vào Module trong trình soạn thảo VBE của Outlook (nhớ kích hoạt tab Developer):
Lưu ý: Macro này sẽ tìm kiếm các email trong thư mục Inbox mặc định trong Outlook.
Mã:Option Explicit Public Sub DownloadAttachments(SenderEmailAddress As String) Dim objMail As Outlook.MailItem Dim objAtt As Outlook.Attachment Dim objFSO As Object Dim strRCDatePath As String, strFolderPath As String, strSenderPath As String Dim i As Long, j As Long Dim strFilter As String, strSenderEmailAddress As String Dim colItems As Outlook.Items Dim objInbox As Outlook.Folder Set objFSO = CreateObject("Scripting.FileSystemObject") strFolderPath = Environ$("USERPROFILE") & "\Documents\OutlookAttachments\" 'Thu muc luu tap tin dinh kem, mac dinh: C:\<nguoidung> If Not objFSO.FolderExists(strFolderPath) Then objFSO.CreateFolder strFolderPath Const PR_SENDER_EMAIL_ADDRESS As String = "http://schemas.microsoft.com/mapi/proptag/0x0C1F001F" Const PR_HASATTACH As String = "http://schemas.microsoft.com/mapi/proptag/0x0E1B000B" strSenderEmailAddress = SenderEmailAddress 'Dia chi email nguoi gui strFilter = "@SQL=" & Quote(PR_SENDER_EMAIL_ADDRESS) & " = '" & strSenderEmailAddress & "' AND " & Quote(PR_HASATTACH) & "=1" Set objInbox = Application.Session.GetDefaultFolder(olFolderInbox) Set colItems = objInbox.Items.Restrict(strFilter) For j = 1 To colItems.Count Set objMail = colItems.Item(j) With objMail If Not objFSO.FolderExists(strFolderPath & GetDateFromReceivedTime(.ReceivedTime)) Then strRCDatePath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) objFSO.CreateFolder strRCDatePath Else: strRCDatePath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) End If If Not objFSO.FolderExists(strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName) Then strSenderPath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName objFSO.CreateFolder strSenderPath Else: strSenderPath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName End If For i = 1 To .Attachments.Count Set objAtt = .Attachments.Item(i) If objFSO.FileExists(strSenderPath & "\" & objAtt.filename) Then objFSO.DeleteFile strSenderPath & "\" & objAtt.filename End If objAtt.SaveAsFile strSenderPath & "\" & objAtt.filename Next i End With Next Shell "explorer """ & strFolderPath & "", vbNormalFocus End Sub Private Function Quote(Text As String) As String Quote = Chr(34) & Text & Chr(34) End Function Private Function GetDateFromReceivedTime(ReceivedDateString As String) As String Dim RDString As String RDString = Trim(Format(Left(ReceivedDateString, InStr(ReceivedDateString, " ")), "dd-mm-yyyy")) GetDateFromReceivedTime = RDString End Function
Khi chạy thủ tục, thay tham số SenderEmailAddress thành địa chỉ email thích hợp, ví dụ:
Mã:Private Sub Test() Call DownloadAttachments("abc@gmail.com") End Sub
Sửa lại một chút macro ở trên.Thật tuyệt vời, những dòng code của anh chạy cực nhanh và chính xác.
Nhờ anh chỉ giúp em nếu muốn thay đổi thư mục mặc định tìm kiếm là Inbox sang 1 thư mục cá nhân khác, và giới hạn thời gian tìm kiếm thì phải sửa code như thế nào ạ.
Public Sub DownloadAttachments(SenderEmailAddress As String, StartDate As Date, EndDate As Date)
Dim objPA As Outlook.PropertyAccessor
Dim dteStartDate As Date, dteEndDate As Date, dteStartDateUTC As Date, dteEndDateUTC As Date
Dim objFolder As Outlook.Folder
dteStartDate = StartDate 'Ngay bat dau, vd: #1/1#2021#
dteEndDate = EndDate 'Ngay ket thuc, vd: #1/1/2022#
Set objMail = Application.CreateItem(olMailItem)
With objMail
Set objPA = .PropertyAccessor
dteStartDateUTC = objPA.LocalTimeToUTC(dteStartDate)
dteEndDateUTC = objPA.LocalTimeToUTC(dteEndDate)
.Close olDiscard
strFilter = "@SQL=" & Quote(PR_SENDER_EMAIL_ADDRESS) & " = '" & strSenderEmailAddress & "' AND " & Quote(PR_HASATTACH) & "=1 AND " & _
Quote("urn:schemas:httpmail:datereceived") & " > " & Chr(39) & dteStartDateUTC & Chr(39) & " And " & Quote("urn:schemas:httpmail:datereceived") & " < " & Chr(39) & dteEndDateUTC & Chr(39)
Set objFolder = Application.Session.PickFolder
If Not objFolder Is Nothing Then
Set colItems = objFolder.Items.Restrict(strFilter)
With objMail
If objFSO.FileExists(strSenderPath & "\" & objAtt.DisplayName) Then
objFSO.DeleteFile strSenderPath & "\" & objAtt.DisplayName
objAtt.SaveAsFile strSenderPath & "\" & objAtt.DisplayName
Private Sub Test()
Call DownloadAttachments("abc@gmail.com", #1/1/2021#, #1/1/2022#)
Cảm ơn anh rất nhiều, code chạy rất chính xác ạ.Sửa lại một chút macro ở trên.
Code dưới đây hiển thị hộp thoại chọn thư mục email để tìm kiếm:
Mã:Option Explicit Public Sub DownloadAttachments(SenderEmailAddress As String, StartDate As Date, EndDate As Date) Dim objMail As Outlook.MailItem Dim objAtt As Outlook.Attachment Dim objPA As Outlook.PropertyAccessor Dim objFSO As Object Dim strRCDatePath As String, strFolderPath As String, strSenderPath As String Dim dteStartDate As Date, dteEndDate As Date, dteStartDateUTC As Date, dteEndDateUTC As Date Dim i As Long, j As Long Dim strFilter As String, strSenderEmailAddress As String Dim colItems As Outlook.Items Dim objFolder As Outlook.Folder Const PR_SENDER_EMAIL_ADDRESS As String = "http://schemas.microsoft.com/mapi/proptag/0x0C1F001F" Const PR_HASATTACH As String = "http://schemas.microsoft.com/mapi/proptag/0x0E1B000B" dteStartDate = StartDate 'Ngay bat dau, vd: #1/1#2021# dteEndDate = EndDate 'Ngay ket thuc, vd: #1/1/2022# Set objMail = Application.CreateItem(olMailItem) With objMail Set objPA = .PropertyAccessor dteStartDateUTC = objPA.LocalTimeToUTC(dteStartDate) dteEndDateUTC = objPA.LocalTimeToUTC(dteEndDate) .Close olDiscard End With strSenderEmailAddress = SenderEmailAddress 'Dia chi email nguoi gui strFilter = "@SQL=" & Quote(PR_SENDER_EMAIL_ADDRESS) & " = '" & strSenderEmailAddress & "' AND " & Quote(PR_HASATTACH) & "=1 AND " & _ Quote("urn:schemas:httpmail:datereceived") & " > " & Chr(39) & dteStartDateUTC & Chr(39) & " And " & Quote("urn:schemas:httpmail:datereceived") & " < " & Chr(39) & dteEndDateUTC & Chr(39) strFolderPath = Environ$("USERPROFILE") & "\Documents\OutlookAttachments\" 'Thu muc luu tap tin dinh kem, mac dinh: C:\<nguoidung> Set objFSO = CreateObject("Scripting.FileSystemObject") If Not objFSO.FolderExists(strFolderPath) Then objFSO.CreateFolder strFolderPath On Error Resume Next Set objFolder = Application.Session.PickFolder If Not objFolder Is Nothing Then Set colItems = objFolder.Items.Restrict(strFilter) For j = 1 To colItems.Count Set objMail = colItems.Item(j) With objMail If Not objFSO.FolderExists(strFolderPath & GetDateFromReceivedTime(.ReceivedTime)) Then strRCDatePath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) objFSO.CreateFolder strRCDatePath Else: strRCDatePath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) End If If Not objFSO.FolderExists(strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName) Then strSenderPath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName objFSO.CreateFolder strSenderPath Else: strSenderPath = strFolderPath & GetDateFromReceivedTime(.ReceivedTime) & "\" & .SenderName End If For i = 1 To .Attachments.Count Set objAtt = .Attachments.Item(i) If objFSO.FileExists(strSenderPath & "\" & objAtt.DisplayName) Then objFSO.DeleteFile strSenderPath & "\" & objAtt.DisplayName End If objAtt.SaveAsFile strSenderPath & "\" & objAtt.DisplayName Next i End With Next Shell "explorer """ & strFolderPath & "", vbNormalFocus End If End Sub Private Function Quote(Text As String) As String Quote = Chr(34) & Text & Chr(34) End Function Private Function GetDateFromReceivedTime(ReceivedDateString As String) As String Dim RDString As String RDString = Trim(Format(Left(ReceivedDateString, InStr(ReceivedDateString, " ")), "dd-mm-yyyy")) GetDateFromReceivedTime = RDString End Function
Sử dụng macro để tìm kiếm và tải xuống tập tin đính kèm từ SenderEmailAddress, trong khoảng thời gian từ ngày StartDate đến ngày EndDate:
Mã:Private Sub Test() Call DownloadAttachments("abc@gmail.com", #1/1/2021#, #1/1/2022#) End Sub
Cho mình hỏi chút.Sửa lại một chút macro ở trên.
Lạ nhỉ, thông thường những thư mục đó chỉ được tạo khi tìm được những email thỏa mãn tiêu chí tìm kiếm. Bạn thử chạy lại xem sao nhé.Cho mình hỏi chút.
Khi mình chạy code thì chỉ tạo ra foder ngày có mail đến thôi. Còn file đính kèm thì không có.
Mình chỉ coppy dán code và thay đổi địa chỉ mail. Không rõ là có cần chỉnh sửa gì nữa không.
Nhờ bạn chỉ giúp.
Em chào Anh,Sửa lại một chút macro ở trên.
Thử code này xem sao nhé, bởi vì bạn sử dụng tài khoản email chuyên dùng để nhận tệp đính kèm nên mình bỏ điều kiện lọc địa chỉ email, chỉ giữ lại điều kiện khoảng ngày, và tất cả những tệp đính kèm thỏa mãn yêu cầu là tệp Excel và tệp pdf đều sẽ được lưu vào chung một thư mục.Em chào Anh,
Giống như code này nếu chỉ muốn lấy những file đính kèm dạng excel và pdf (Hoặc tìm và lọc theo dạng tên file) trong nguyên 1 thư mục luôn thì có được không ạ, vì như bên em sử dụng những địa chỉ email chuyên để nhận file từ nhiều khách hàng, hàng ngày em phải trích lưu những file đính kèm của nhiều bên gửi tới hộp mail chung đó nên việc chỉ định lấy theo từng Sender sẽ không hiệu quả. Mong anh hướng dẫn giúp.
Public Sub DownloadAttachments(StartDate As Date, EndDate As Date)
Dim strFolderPath As String, strDateTimeFolder As String
With objMail
.Close olDiscard
strFilter = "@SQL=" & Quote(PR_HASATTACH) & "=1 AND " & _
If Not objFSO.FolderExists(strFolderPath & Format$(Now, "dd-mm-yyyy hh.nn.ss")) Then
strDateTimeFolder = strFolderPath & Format$(Now, "dd-mm-yyyy hh.nn.ss")
objFSO.CreateFolder strDateTimeFolder
Else: strDateTimeFolder = strFolderPath & Format$(Now, "dd-mm-yyyy hh.nn.ss")
With objMail
Select Case objFSO.GetExtensionName(objAtt.filename)
Case "xlsx", "xls", "xlsm", "pdf"
If objFSO.FileExists(strDateTimeFolder & "\" & objAtt.filename) Then
objFSO.DeleteFile strDateTimeFolder & "\" & objAtt.filename
objAtt.SaveAsFile strDateTimeFolder & "\" & objAtt.filename
End Select
Nếu hàng ngày phải trích lưu những tệp đính kèm như thế này thì bạn nên viết macro để Outlook tự động tải xuống tệp đính kèm mỗi khi nhận được email là được.hàng ngày em phải trích lưu những file đính kèm của nhiều bên gửi tới hộp mail chung đó nên việc chỉ định lấy theo từng Sender sẽ không hiệu quả.
Em cảm ơn anh, em đã chạy thử và thấy mã code của anh đã lấy được các file đính kèm gom chung vào 1 thư mục, kết quả đã đúng ạ. Chỉ lưu ý là muốn lấy dữ liệu tới ngày nào thì phải gõ EndDate sau hôm đó 1 ngày.Nếu hàng ngày phải trích lưu những tệp đính kèm như thế này thì bạn nên viết macro để Outlook tự động tải xuống tệp đính kèm mỗi khi nhận được email là được.
Nếu bạn có thắc mắc gì về Outlook VBA, bạn có thể liên hệ với mình để được giải quyết.Em cảm ơn anh, em đã chạy thử và thấy mã code của anh đã lấy được các file đính kèm gom chung vào 1 thư mục, kết quả đã đúng ạ. Chỉ lưu ý là muốn lấy dữ liệu tới ngày nào thì phải gõ EndDate sau hôm đó 1 ngày.
Hiện tại em cũng mới học VBA căn bản, giáo trình và video hướng dẫn của Excel rất nhiều, tuy nhiên về phần Outlook thì lại ít tài liệu hướng dẫn hơn. Cảm ơn anh đã chỉ dẫn, em sẽ cố gắng thêm.
À quên nữa, bổ sung thêm cái này.Em cảm ơn anh, em đã chạy thử và thấy mã code của anh đã lấy được các file đính kèm gom chung vào 1 thư mục, kết quả đã đúng ạ. Chỉ lưu ý là muốn lấy dữ liệu tới ngày nào thì phải gõ EndDate sau hôm đó 1 ngày.
Public Enum DateTimeMacro
Today
Tomorrow
Yesterday
Next7days
Last7days
NextWeek
ThisWeek
LastWeek
NextMonth
ThisMonth
LastMonth
End Enum
Public Sub DownloadAttachments(Optional UseDateTimeMacro As Boolean = False, Optional DateTimeMacro As DateTimeMacro, Optional StartDate As Date, Optional EndDate As Date)
Dim strDateTimeMacro As String
If UseDateTimeMacro = False Then
With objMail
.Close olDiscard
Select Case DateTimeMacro
Case Today
strDateTimeMacro = "%today(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case Tomorrow
strDateTimeMacro = "%tomorrow(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case Yesterday
strDateTimeMacro = "%yesterday(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case Next7days
strDateTimeMacro = "%next7days(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case Last7days
strDateTimeMacro = "%last7days(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case NextWeek
strDateTimeMacro = "%nextweek(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case ThisWeek
strDateTimeMacro = "%thisweek(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case LastWeek
strDateTimeMacro = "%lastweek(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case NextMonth
strDateTimeMacro = "%nextmonth(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case ThisMonth
strDateTimeMacro = "%thismonth(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
Case LastMonth
strDateTimeMacro = "%lastmonth(" & Quote("urn:schemas:httpmail:datereceived") & ")%"
End Select
strFilter = "@SQL=" & strDateTimeMacro & " AND " & Quote(PR_HASATTACH) & "=1 "
If Not objFolder Is Nothing And objFolder.DefaultItemType = olMailItem Then
With objMail
End Select
Else: MsgBox "You must select a folder that contains email items only.", vbExclamation, "Error: Invalid Folder"
Private Sub SaveEmailAttachments()
Call DownloadAttachments(UseDateTimeMacro:=True, DateTimeMacro:=Today)
