Thử code.file cần giúp đỡ là file (dichuyen), bác thanhmai103309 có giúp e viết code ( book1) nhưng quá trình có phát sinh lỗi là số di chuyển + số còn lại đang lớn hơn số đã cho ah. e cảm ơn!
Sub abc()
Dim i As Long, lr As Long, dic As Object, arr, kq, a As Long, dk As String
With Sheets("sheet1")
lr = .Range("G" & Rows.Count).End(xlUp).Row
arr = .Range("G2:H" & lr).Value
For i = 1 To UBound(arr)
dk = arr(i, 1)
dic.Item(dk) = i
lr = .Range("A" & Rows.Count).End(xlUp).Row
arr = .Range("A2:C" & lr).Value
ReDim kq(1 To UBound(arr), 1 To 3)
dk = arr(i, 1)
If dic.exists(dk) Then
a = a + 1
kq(a, 1) = arr(i, 1)
kq(a, 2) = arr(i, 2)
kq(a, 3) = arr(i, 3)
lr = .Range("K" & Rows.Count).End(xlUp).Row
If a > 1 Then .Range("K2:M" & lr).ClearContents
If a Then .Range("K2:m2").Resize(a).Value = kq
Set dic = Nothing
em cảm ơn, file chạy được rồi ahThử code.
Mã:Sub abc() Dim i As Long, lr As Long, dic As Object, arr, kq, a As Long, dk As String Set dic = CreateObject("scripting.dictionary") With Sheets("sheet1") lr = .Range("G" & Rows.Count).End(xlUp).Row arr = .Range("G2:H" & lr).Value For i = 1 To UBound(arr) dk = arr(i, 1) dic.Item(dk) = i Next i lr = .Range("A" & Rows.Count).End(xlUp).Row arr = .Range("A2:C" & lr).Value ReDim kq(1 To UBound(arr), 1 To 3) For i = 1 To UBound(arr) dk = arr(i, 1) If dic.exists(dk) Then a = a + 1 kq(a, 1) = arr(i, 1) kq(a, 2) = arr(i, 2) kq(a, 3) = arr(i, 3) End If Next i lr = .Range("K" & Rows.Count).End(xlUp).Row If a > 1 Then .Range("K2:M" & lr).ClearContents If a Then .Range("K2:m2").Resize(a).Value = kq End With Set dic = Nothing End Sub
