Xin giúp đỡ chỉnh code VBA (4 người xem)
happyghost2000
Các bác ơi ! giúp em chỉnh code dùm.
Em có đoạn code bên dưới . Em muốn dùm mãng để hứng kết quả & hiện thị thay thế cho Cells( i, .....)
Vì dùng cells code chạy chậm quá à.
Mong các bác giúp em .
Sub tinhthieu()
Dim i As Long, lr As Long
Dim Tong1 As Long, Tong2&, Tong3&
Dim Arr()
Sheet12.Range("P4:R100000").ClearContents
lr = Sheet12.Range("A10000").End(xlUp).row
Arr = Sheet12.Range("A4:S" & lr).Value
'redim Tong1 = Sheet12.Range("U4:U" & lr).Value
For i = 1 To UBound(Arr, 1)
If Arr(i, 13) - Arr(i, 12) - Arr(i, 10) > 0 Then
Cells(i + 3, 16) = Arr(i, 13) - Arr(i, 12) - Arr(i, 10)
If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - Cells(i + 3, 16) > 0 Then
Cells(i + 3, 17) = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - Cells(i + 3, 16)
If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - Cells(i + 3, 16) - Cells(i + 3, 17) > 0 Then
Cells(i + 3, 18) = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - Cells(i + 3, 16) - Cells(i + 3, 17)
'Sheet12.Range("u4:w100000").ClearContents
'Sheet12.Range("U4:U" & lr).Resize = Tong1
'Sheet12.Range("V4:V" & lr).Resize = Tong2
'Sheet12.Range("W4:W" & lr).Resize = Tong3
Bạn tham khảo con ni xem sao:
Sub TinhtHieu()
 Dim i As Long, lR As Long
 Dim Tmr As Double, Tong16 As Double, Tong17 As Double, Tong18 As Double
 Dim Arr()
9 Sheet12.Range("P4:R100000").ClearContents '???    '
 Tmr = Timer()
 lR = Sheet12.Range("A10000").End(xlUp).Row
 ReDim aKQ(1 To lR, 1 To 3)
 Arr = Sheet12.Range("A4:S" & lR).Value
        Tong16 = Arr(i, 13) - Arr(i, 12) - Arr(i, 10)
1       ' Cells(i + 3, 16) = Arr(i, 13) - Arr(i, 12) - Arr(i, 10) '
        aKQ(i, 1) = Tong16
    If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - Tong16 > 0 Then
'    If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - Cells(i + 3, 16) > 0 Then    '
        Tong17 = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - Tong16
2 '        Cells(i + 3, 17) = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - Cells(i + 3, 16)
        aKQ(i, 2) = Tong17
    If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - Cells(i + 3, 16) - Tong17 > 0 Then
'    If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - Cells(i + 3, 16) - Cells(i + 3, 17) > 0 Then
3         Tong18 = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - Tong16 - Tong17
'        Cells(i + 3, 18) = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - Cells(i + 3, 16) - Cells(i + 3, 17)'
        aKQ(i, 3) = Tong18
[P4].Resize(i, 3).Value = aKQ():                    MsgBox Timer() - Tmr
Arr(i, 10) + Arr(i, 12) - Arr(i, 13) là một biểu thức được tính đến mấy lần !!!
Sub TinhtHieu()
 Dim Arr()
 Tmr = Timer()
        aKQ(i, 1) = Tong16
        aKQ(i, 2) = Tong17
        aKQ(i, 3) = Tong18
Em cám ơn Bác Nhiều . Code chạy rất nhanh. Nhưng có 1 số kết quả không chính xác , để em tìm hiểu thêm. Nếu không tìm ra, em sẽ chạy lên xin giúp đỡ tiếp. Một lần nữa cám ơn bác
Lẽ ra bạn nên đưa file lên, người hướng dẫn sẽ biết cách chỉnh lại các vấn đề lỗi.
Dạ em biết sai rồi . Em xin bổ sung file đính kèm .
Cột P~R : dùng code Cells
Cột S~U : dùng code mãng bác SA_DQ .
Khi em so kết quả có sự sai biệt ạ .
Mong các bác giúp em ạ . @SA_DQ , @Hoàng Trọng Nghĩa
  • Book1.xlsm
    Book1.xlsm
    356 KB · Đọc: 11
    96.7 KB · Đọc: 13
Upvote 1
Em đã chỉnh lại như sau & kết quả đã ra đúng !!!!.
Sub TinhtHieu_Mang3()
Dim Tmr As Double
Dim Tong16(), Tong17(), Tong18()
Dim Arr()
Sheet12.Range("S4:U100000").ClearContents '??? '
Tmr = Timer()
ReDim kq1(1 To 10000, 1 To 1)
ReDim kq2(1 To 10000, 1 To 1)
ReDim kq3(1 To 10000, 1 To 1)
Arr = Sheet12.Range("A4:R" & lR).Value
kq1(i, 1) = Arr(i, 13) - Arr(i, 12) - Arr(i, 10)
'kq1(i, 1) = Tong16
If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - kq1(i, 1) > 0 Then
kq2(i, 1) = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14)) - kq1(i, 1)
'kq2(i, 2) = Tong17
If -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - kq1(i, 1) - kq2(i, 1) > 0 Then
kq3(i, 1) = -(Arr(i, 10) + Arr(i, 12) - Arr(i, 13) - Arr(i, 14) - Arr(i, 15)) - kq1(i, 1) - kq2(i, 1)
'kq3(i, 3) = Tong18
[S4].Resize(i, 1).Value = kq1()
[T4].Resize(i, 1).Value = kq2()
[U4].Resize(i, 1).Value = kq3()
Làm đại, trật làm lại.
Sub TinhtHieu_Cell()
Dim i&, lr&, T1 As Double, T2 As Double, T3 As Double
Dim arr
lr = Sheet12.Cells(Rows.Count, "J").End(xlUp).Row
arr = Sheet12.Range("J4:R" & lr).Value
For i = 1 To UBound(arr)
    T1 = arr(i, 1) + arr(i, 3) - arr(i, 4)
    T2 = T1 - arr(i, 5)
    T3 = T2 - arr(i, 6)
    If T1 < 0 Then arr(i, 7) = -T1
    If T2 < 0 Then arr(i, 8) = -T2 - arr(i, 7)
    If T3 < 0 Then arr(i, 9) = -T3 - arr(i, 7) - arr(i, 8)
Sheet12.Range("J4").Resize(UBound(arr), UBound(arr, 2)).Value = arr
Dim arr
    T2 = T1 - arr(i, 5)
    T3 = T2 - arr(i, 6)
Code bác hay quá trời luôn. Em học được thêm thuật toán tuyệt vời Ông mặt trời.
Cám ơn bác nhiều lắm.
Chân thành cảm ơn 2 bác @bebo021999 & bác @SA_DQ
Bác dịch dùm em câu lệnh này giúp. Em chưa hiểu ạ. Em thấy hay quá mà không hiểu, .Mong bác giúp em .
