MỹHạnhCB
Đi mây, về gió. !!!
Nhờ các anh chị xem giúp em có thể tinh gọn đoạn mã (code) này ạ, em mày mò được vậy nhưng khi chạy xoay vòng hơi lâu ạ ( tầm 4s ). Cảm ơn các anh chị
Sub getinfo_Film1()
Dim fileExplorer As FileDialog
Dim filepath(300) As String
Dim wb As Workbook, ws As Worksheet
Dim lr, lr1 As Integer
Dim fso As Object
'Application.Calculation = xlCalculationManual
Application.AskToUpdateLinks = False
Set ex1 = ThisWorkbook.Sheets("DANHMUCLOAINHA")
Sheets.Add.Name = "Mau1"
Set fileExplorer = Application.FileDialog(msoFileDialogFilePicker)
With fileExplorer
.Title = "Select Log Film"
.AllowMultiSelect = True
.Filters.Clear
.Filters.Add "xlsx file", "*.xlsx"
.InitialFileName = ""
If .Show <> -1 Then Exit Sub
For i = 1 To .SelectedItems.Count
filepath(i) = .SelectedItems(i)
i = 1
While filepath(i) <> ""
Set wb = Workbooks.Open(filepath(i))
Set ws = wb.Sheets(1)
lr = ws.Cells(Rows.Count, 3).End(xlUp).Row
ws.Range(Cells(2, "B"), Cells(lr, "F")).Copy ThisWorkbook.Sheets("Mau1").Cells(1, "A")
wb.Close
ThisWorkbook.Sheets("Mau1").Range(Cells(1, "B"), Cells(lr, "B")).Cut
Columns("A:A").Insert Shift:=xlToRight
Range(Cells(1, "A"), Cells(lr, "D")).Sort Key1:=Range("D1"), Order1:=xlAscending, Header:=xlNo
ex1.Cells(2, "M") = "=IF(RC[-4]<>"""",VLOOKUP(RC[-11],'Mau1'!R1C1:R88C2,2,0),VLOOKUP(RC[-11],'Mau1'!R46C1:R88C2,2,0))"
ex1.Cells(2, "C") = "=CODE!R13C2"
ex1.Cells(2, "D") = "=CODE!R14C2"
ex1.Visible = True 'xlSheetHidden
ex1.Select
lr1 = ex1.Cells(Rows.Count, 5).End(xlUp).Row
ex1.Range(Cells(2, "E"), Cells(lr1, "E")).Copy ex1.Cells(2, "F")
ex1.Range(Cells(2, "A"), Cells(lr1, "M")).Copy
ex1.Cells(2, "A").PasteSpecial , Paste:=xlPasteValues
ex1.Range(Cells(2, "B"), Cells(lr1, "B")).Clear
Sheets("Mau1").Delete
With Application
ex1.Copy
ActiveWorkbook.Close True, ThisWorkbook.Path & "\DANHMUCLOAINHA"
i = i + 1
ex1.Visible = xlSheetHidden
Wend
'Application.Calculation = xlCalculationAutomatic
Application.AskToUpdateLinks = True
'Range("E2:F300").NumberFormat = "yyyy-mm-dd hh:mm:ss"
MsgBox "HoanThanh"
