ok95sonok
Sub chenanh()
Dim FilesToOpen As Variant
Dim numberOfPics As Integer
Dim numberOfPicsPerRow As Integer
Dim numberOfRows As Integer
Dim picWidth As Double, picHeight As Double, gap As Double
Dim count As Integer
FilesToOpen = Application.GetOpenFilename(Title:="chon anh", MultiSelect:=True)
numberOfPics = UBound(FilesToOpen)
numberOfPicsPerRow = [A1]
picWidth = [B1]
picHeight = [C1]
gap = [D1]
count = 1
numberOfRows = WorksheetFunction.Ceiling(numberOfPics / numberOfPicsPerRow, 1)
For i = 1 To numberOfRows
For j = 1 To numberOfPicsPerRow
If count <= numberOfPics Then
With ActiveSheet.Pictures.Insert(FilesToOpen(count))
With .ShapeRange
.LockAspectRatio = True
.Width = picWidth
.Height = picHeight
.Left = gap * j + picWidth * (j + 1)
.Top = gap * i + picHeight * (i + 1)
count = count + 1
FilesToOpen = Application.GetOpenFilename(FileFilter:="Anh (*.bmp; *.gif; *.jpg; *.png), *.bmp; *.gif; *.jpg; *.png", Title:="chon anh", MultiSelect:=True)
With .ShapeRange
.Width = picWidth
.Height = picHeight
ActiveSheet.Shapes.AddPicture FilesToOpen(count), msoFalse, msoTrue, gap * j + picWidth * (j + 1), gap * i + picHeight * (i + 1), picWidth, picHeight
cảm ơn anh rất nhiều!Thay
Mã:FilesToOpen = Application.GetOpenFilename(Title:="chon anh", MultiSelect:=True)
bằng
Mã:FilesToOpen = Application.GetOpenFilename(FileFilter:="Anh (*.bmp; *.gif; *.jpg; *.png), *.bmp; *.gif; *.jpg; *.png", Title:="chon anh", MultiSelect:=True)
Thay
Mã:With ActiveSheet.Pictures.Insert(FilesToOpen(count)) With .ShapeRange .LockAspectRatio = True .Width = picWidth .Height = picHeight End With .Left = gap * j + picWidth * (j + 1) .Top = gap * i + picHeight * (i + 1) End With
bằng
Mã:ActiveSheet.Shapes.AddPicture FilesToOpen(count), msoFalse, msoTrue, gap * j + picWidth * (j + 1), gap * i + picHeight * (i + 1), picWidth, picHeight
Tôi chịu.cảm ơn anh rất nhiều!
cho e hỏi thêm là làm thế nào để giữ nguyên chất lượng ảnh được ạ. em chèn xong ảnh mờ quá
em cho kích thước ảnh to ra được rồi ạ. cảm ơn pro nhiều ạ!Tôi chịu.
Nhưng tôi có chút tò mò. Ảnh nhìn thấy trên sheet và ảnh thực ngoài đĩa có khác nhau nhiều về kích thước không? Vd. ảnh ngoài đĩa so với trên sheet rất nhỏ (rất to).
Nhưng tôi nói rồi - tôi chịu. Hay là thử mở ảnh thực trên sheet sau khi click, và thu lại như cũ khi click lần nữa? Nhưng tôi cũng không biết ảnh thực trên sheet chất lượng sẽ như thế nào. Vì tôi chưa gặp trường hợp ảnh kém chất lượng nhưng từng nghe có người phàn nàn.
picWidth = [B1]
picHeight = [C1]
Tôi giúp bạn thì bạn cũng phải giúp tôi.em cho kích thước ảnh to ra được rồi ạ. cảm ơn pro nhiều ạ!
ảnh ngoài đĩa chất lương cao nhưng khi vào sheet vỡ ảnh cho đoạn này to ra là được ạ, mới đầu em để 100*100
HTML:picWidth = [B1] picHeight = [C1]
Tôi muốn biết tại sao ảnh lại kém chất lượng. Tôi muốn biết nguyên nhân. Rất có thể câu trả lời của bạn sẽ cho tôi một gợi ý.Nhưng tôi có chút tò mò. Ảnh nhìn thấy trên sheet và ảnh thực ngoài đĩa có khác nhau nhiều về kích thước không? Vd. ảnh ngoài đĩa so với trên sheet rất nhỏ (rất to).
em thấy ảnh trong sheet theo code để 100*100Tôi giúp bạn thì bạn cũng phải giúp tôi.
Tôi viết rất rõ
Thì đúng rồi. Chiều dài thu nhỏ tận 20 lần, chiều cao thu nhỏ 13 lần. Do 2 chiều thu nhỏ không đều nên ảnh còn bị méo.em thấy ảnh trong sheet theo code để 100*100
còn ảnh thực tế 2048*1365
sau khi em cho trong sheet lên 300*200 ảnh đã cải thiện rất là nhiều ạ
Vâng anh. em mới biết đến 4rum và đọc một vài bài viết thấy anh rất nhiệt tình giúp đỡ mọi người. tiện thể cho em hỏi thêm có thể tạo 1 trường hợp chèn ảnh nữa tương tự code của em ở trên được không ạ?Thì đúng rồi. Chiều dài thu nhỏ tận 20 lần, chiều cao thu nhỏ 13 lần. Do 2 chiều thu nhỏ không đều nên ảnh còn bị méo.
Cái này em đoán là khi trèn ảnh lên không bị giảm độ phân giải.Mà khi lưu file lại nó tự động điều chỉnh độ phân giải về với kích thước ảnh hiện có nên khi phóng to ra sẽ bị vỡ ảnh.Tôi giúp bạn thì bạn cũng phải giúp tôi.
Tôi viết rất rõ
Không phải anh ạ, em chưa lưu. em để rộng 100, cao 100 chắc nhỏ quá nên nó vỡ luôn lúc chèn vào. ảnh gốc rộng 2048*1365Cái này em đoán là khi trèn ảnh lên không bị giảm độ phân giải.Mà khi lưu file lại nó tự động điều chỉnh độ phân giải về với kích thước ảnh hiện có nên khi phóng to ra sẽ bị vỡ ảnh.
Với code chèn ảnh của tôi tuy ảnh nhỏ do tác giả muốn thu nhỏ về 300 x 200 nhưng ảnh gốc to vẫn luôn có. Tuần sau tôi thêm code vào để gọi ảnh gốc thì sẽ hiển thị ảnh gốc to như nguyên bản. Nó không phải là ảnh nhỏ 300 x 200 được phóng to như ảnh gốc mà nó đúng là ảnh khi ta chọn trên đĩa.Cái này em đoán là khi trèn ảnh lên không bị giảm độ phân giải.Mà khi lưu file lại nó tự động điều chỉnh độ phân giải về với kích thước ảnh hiện có nên khi phóng to ra sẽ bị vỡ ảnh.
Tức có 24 khung là 24 ô E2:H7. Bây giờ bạn muốn chèn 24 ảnh vào 24 ô đó. Và chèn vĩnh viễn (LinkToFile = False) và không vừa khít khung mà CENTER trong khung?Em có 24 ảnh trong ổ đĩa số từ 1 đến 24
em muốn chèn ảnh vào 4 cột trong sheet vòng lặp các hàng tiếp theo (mỗi ô trong cột Width = 300, Height = 200)
như code hiện tại em phải CTRL + A rồi di chuyển 24 ảnh vào vị trí muốn chèn
giờ em muốn khi chèn ảnh sẽ tự Center vào ô mình muốn có được không ạ?
Hí anh. em vừa đọc bài và lấy file của a về chỉnh sửa. anh cho em hỏi làm thế nào để tên ở ô nào, cột nào thì ảnh ở đấy được không ạ?Với code chèn ảnh của tôi tuy ảnh nhỏ do tác giả muốn thu nhỏ về 300 x 200 nhưng ảnh gốc to vẫn luôn có. Tuần sau tôi thêm code vào để gọi ảnh gốc thì sẽ hiển thị ảnh gốc to như nguyên bản. Nó không phải là ảnh nhỏ 300 x 200 được phóng to như ảnh gốc mà nó đúng là ảnh khi ta chọn trên đĩa.
Nếu thế thì hãy đọc kỹ bài #2
[Xin ý kiến] Điều chỉnh kích thước ảnh cho vừa ô
Chào mọi người, Mình có file gồm cột A (họ tên) và cột B (hình ảnh). File này là do chi nhánh gửi về. Do làm thủ công nên hình ảnh có thể không vừa khít ô. Mình nhờ moi người giúp đỡ đoạn code hoặc công cụ nào có thể xử lý ảnh hàng loạt cho vừa khít ô ở cột B. Cám ơn mọi người rất nhiều.www.giaiphapexcel.com
Quan trọng nhất là sub InsertPicture. Tùy tình huống mà dùng vòng FOR và trong vòng For thì gọi InsertPicture để chèn ảnh. Với InsertPicture bạn có thể chèn ảnh vào khung là 1 hoặc nhiều ô mà không cần merge cell, chèn ảnh thực hoặc vừa khít ô hoặc center, và chèn vĩnh viễn (LinkToFile = False) hoặc chỉ chèn link.
Trong tập tin bạn có vùng cố định B5:E10 rồi còn gì, sao lại phải .Cells(Rows.Count, "E").End(xlUp).Row làm gì?Hí anh. em vừa đọc bài và lấy file của a về chỉnh sửa. anh cho em hỏi làm thế nào để tên ở ô nào, cột nào thì ảnh ở đấy được không ạ?
If LinkToFile Then
Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoTrue, msoFalse, Target.left, Target.top, 0, 0)
Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoFalse, msoTrue, Target.left, Target.top, 0, 0)
If LinkToFile Then
Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoFalse, msoFalse, Target.left, Target.top, 0, 0)
Sub chen_anh()
Const dong_dau = 5
Const cot_dau = "B"
Const so_cot = 4
Dim lastRow As Long, vung As range, cell_ As range
With ThisWorkbook.Worksheets("Sheet1")
lastRow = .Cells(Rows.Count, cot_dau).End(xlUp).Row ' dong cuoi cung co du lieu trong cot B
If lastRow < dong_dau Then Exit Sub
Set vung = .range(cot_dau & dong_dau).Resize(lastRow - dong_dau + 1, so_cot)
For Each cell_ In vung
InsertPicture ThisWorkbook.path & "\Anh\" & cell_.Value & ".jpg", cell_, False, True, False
Next cell_
Sub InsertPicture(ByVal PicFilename As String, Optional Target As range = Nothing, _
Optional original As Boolean = False, Optional center As Boolean = False, _
Optional LinkToFile As Boolean = False)
' Target: vung nhap anh. Co the la nhieu cell
' Neu Target = Nothing thi Target = ActiveCell
' Neu original = True thi nhap anh kich thuoc thuc.
' Neu original = FALSE thi neu center = True thi anh se center trong vung Target,
' nguoc lai thi se vua khit vung Target
' LinkToFile = False thi khong can giu anh tren dia, nguoc lai bat buoc phai giu anh de moi lan mo thi co
Dim w As Double, h As Double, shp As Shape, fso As Object
If Target Is Nothing Then Set Target = ActiveCell
Target.Parent.Shapes(Target.Address).Delete
On Error GoTo 0
If fso.FileExists(PicFilename) Then
If LinkToFile Then
If Not shp Is Nothing Then
With shp
If original Then
.ScaleWidth 1, msoTrue
.ScaleHeight 1, msoTrue
ElseIf center Then
w = Target.Width
h = w * .Height / .Width
If h > Target.Height Then
h = Target.Height
w = h * .Width / .Height
.left = Target.left + (Target.Width - w) / 2
.top = Target.top + (Target.Height - h) / 2
.Width = w
.Height = h
.Width = Target.Width
.Height = Target.Height
shp.Name = Target.Address
shp.Placement = xlMoveAndSize
Set fso = Nothing
Đạ tạ tiền bối. Thực sự em cũng mới biết về VBA. Cảm ơn anh rất nhiều ạ!Trong tập tin bạn có vùng cố định B5:E10 rồi còn gì, sao lại phải .Cells(Rows.Count, "E").End(xlUp).Row làm gì?
Hay là không hẳn là bắt đầu từ dòng 5 và không hẳn kết thúc ở dòng 10? Và phải biết xét những dòng nào.
Vd. vùng cần xét LUÔN LUÔN từ dòng 5, cột LUÔN LUÔN là B:E. Và cột B luôn chứa dòng cuối cùng có dữ liệu (vì nếu giả sử trong tập tin bạn chỉ nhập tới E10 còn B10, C10, D10 rỗng thì cột B không chứa đòng cuối cùng có dữ liệu là dòng 10) ...
Để dễ bảo trì thì tôi định nghĩa 3 hằng số:
Const dong_dau = 5 ' chỉ số dòng đầu
Const cot_dau = "B" ' tên cột đầu
Const so_cot = 4 ' số cột.
Trong trường hợp cụ thể thì sửa 3 hằng số này.
Nếu tên ở ô nào thì ảnh ở ô đó thì phải là cell_ chứ sao lại là cell_.Offset(0, 1)?
À, có một điều quan trọng bạn đã làm sai. Không được sửa code của sub InsertPicture. Đây là sub tổng quát, bất di bất dịch. Khi muốn chèn ảnh vĩnh viễn, hay chèn center, hay chèn ảnh kích thức thực thì truyền True, False khi GỌI InsertPicture. Nhưng code của sub InsertPicture không động vào - nguy hiểm chết người!
Trong tập tin bạn đã sửa lại code của InsertPicture, ít nhất là 1 chỗ.
Của tôi viết là
Mã:If LinkToFile Then Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoTrue, msoFalse, Target.left, Target.top, 0, 0) Else Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoFalse, msoTrue, Target.left, Target.top, 0, 0) End If
Trong tập tin của bạn có
--------------------------Mã:If LinkToFile Then Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoFalse, msoTrue, Target.left, Target.top, 0, 0) Else Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoFalse, msoFalse, Target.left, Target.top, 0, 0) End If
Mã:Sub chen_anh() Const dong_dau = 5 Const cot_dau = "B" Const so_cot = 4 Dim lastRow As Long, vung As range, cell_ As range With ThisWorkbook.Worksheets("Sheet1") lastRow = .Cells(Rows.Count, cot_dau).End(xlUp).Row ' dong cuoi cung co du lieu trong cot B If lastRow < dong_dau Then Exit Sub Set vung = .range(cot_dau & dong_dau).Resize(lastRow - dong_dau + 1, so_cot) End With For Each cell_ In vung InsertPicture ThisWorkbook.path & "\Anh\" & cell_.Value & ".jpg", cell_, False, True, False Next cell_ End Sub
Code trên chèn ảnh vĩnh viễn. Nếu chỉ muốn chèn link thì tham số cuối là TRUE. Code chèn ảnh CENTER. Nếu muốn vừa khít khung thì tham số trước cuối là FALSE.
Tôi gửi lại code InsertPicture. Không đụng vào sub này - nguy hiểm chết người.
Mã:Sub InsertPicture(ByVal PicFilename As String, Optional Target As range = Nothing, _ Optional original As Boolean = False, Optional center As Boolean = False, _ Optional LinkToFile As Boolean = False) ' Target: vung nhap anh. Co the la nhieu cell ' Neu Target = Nothing thi Target = ActiveCell ' Neu original = True thi nhap anh kich thuoc thuc. ' Neu original = FALSE thi neu center = True thi anh se center trong vung Target, ' nguoc lai thi se vua khit vung Target ' LinkToFile = False thi khong can giu anh tren dia, nguoc lai bat buoc phai giu anh de moi lan mo thi co Dim w As Double, h As Double, shp As Shape, fso As Object If Target Is Nothing Then Set Target = ActiveCell On Error Resume Next Target.Parent.Shapes(Target.Address).Delete On Error GoTo 0 Set fso = CreateObject("Scripting.FileSystemObject") If fso.FileExists(PicFilename) Then If LinkToFile Then Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoTrue, msoFalse, Target.left, Target.top, 0, 0) Else Set shp = Target.Parent.Shapes.AddPicture(PicFilename, msoFalse, msoTrue, Target.left, Target.top, 0, 0) End If If Not shp Is Nothing Then With shp If original Then .ScaleWidth 1, msoTrue .ScaleHeight 1, msoTrue ElseIf center Then .ScaleWidth 1, msoTrue .ScaleHeight 1, msoTrue w = Target.Width h = w * .Height / .Width If h > Target.Height Then h = Target.Height w = h * .Width / .Height End If .left = Target.left + (Target.Width - w) / 2 .top = Target.top + (Target.Height - h) / 2 .Width = w .Height = h Else .Width = Target.Width .Height = Target.Height End If shp.Name = Target.Address shp.Placement = xlMoveAndSize End With End If End If Set fso = Nothing End Sub
