Mình xin lỗi, mình cũng đang bị lỗi khi sử dụng 1 file VBA, nhờ bạn xem giúp, lỗi error 13 đoạn code như sau (khi bấm debug thì nó ra chỗ dòng màu vàng):
Public sSoCT As String
Dim curCho&, curNhan&
Dim curSLCho As Double, curSLNhan As Double
Dim curSLChoDu As Double, curSLNhanThieu As Double, SLChia As Double
Dim rngCho As Range, rngNhan As Range, rngData As Range, rngDMTK As Range
Dim endR&, eRow&, eR&, iR&, iRow&, SoDong&
Dim i&, j&, k&, m&, s&, T&, u&, n&
Dim DemNo&, DemCo&, Dem&, dongDau&, iCT&
Dim Wf As WorksheetFunction, Dic As Object
Const ColTkNo = 8: Const ColTkCo = 9: Const RowEnd = 400000
Dim Arr(), ArrNo(), ArrCo(), ArrTK(), arrCho(), arrNhan(), ArrSap(), ArrDM(), ArrSoCT()
Dim Tg
Dim ArrKq(1 To 2000, 1 To 16)
Sub TaoRng()
Set Wf = WorksheetFunction
iRow = 2 'dong dau NKC
With Sheets("NKC")
.Range("A" & iRow & "
" & RowEnd).ClearContents
With Sheets("Tmp")
endR = .Range("A" & RowEnd).End(xlUp).Row
ArrTK = .Range(.Cells(2, 14), .Cells(u, 16)).Value
dongDau = 0
eRow = UBound(ArrTK)
For iCT = 1 To eRow
sSoCT = ArrTK(iCT, 1) 'so CT
Dem = ArrTK(iCT, 2) + ArrTK(iCT, 3) 'so lan N + C
If Dem = 0 Then GoTo exit_for
''Day la phan tinh toan cac TH, co ban la xac dinh cac vung RngCho va RngNhan'
DemNo = ArrTK(iCT, 2) 'so lan N'
DemCo = ArrTK(iCT, 3) 'so lan C'
TaoSubRng
'Truong hop nay la toan No
If DemCo = 0 Then
TinhToan07
GoTo exit_for
''Truong hop nay la toan Co
If DemNo = 0 Then
TinhToan08
GoTo exit_for
''Truong hop khac - TH nay nhieu nhat
'Truong hop nay la soct vua co No vua co Co
Select Case Dem
Case 2
''luc nay DemNo=1 va demCo =1
TinhToan01
Case Is > 2 'so record > 2
''Them 1 TH neu so TK No = So TK Co, STien No(1)=sotienco(1), SotienNo(end)=sotienco(end)
If Dem < 5 And DemNo = DemCo Then
If rngNhan(1, 9) = rngCho(1, 8) And rngNhan(DemCo, 9) = rngCho(DemNo, 8) Then
TinhToan04
GoTo exit_for
If DemNo = 1 Then 'quan he 1N nhieu C
TinhToan02
GoTo exit_for
If DemCo = 1 Then 'quan he 1C nhieu N
TinhToan03
GoTo exit_for
''quan he nhieu no nhieu co
If Wf.CountIf(rngCh
ffset(, 7).Resize(, 1), "<0") = DemNo Then
''Truong hop nay la so tien No toan am
TinhToan06
GoTo exit_for
TinhToan05
GoTo exit_for
End Select
exit_for:
dongDau = dongDau + Dem
If dongDau >= endR Then Exit Sub
Next iCT
Erase ArrTK, arrCho(), arrNhan(), ArrKq
Set rngCho = Nothing: Set rngNhan = Nothing
Sub TaoNKC()
With Application
.ScreenUpdating = False: .DisplayAlerts = False: .Calculation = xlCalculationManual: .EnableEvents = False
Tg = Timer
Sheets("NKC").Select
Sheets("NKC").AutoFilterMode = False
'Co the them 1 UDF kiem tra sh Tmp da ton tai
If SheetExists("Tmp") Then
With Sheets("Tmp")
.Cells.ClearContents
.[B1] = "SoCT" 'them tieu de
.[N1] = "SoCT": .[O1] = "DemNo": .[P1] = "DemCo": .[Q1] = "NgayHT"
'Neu chua co thi add
Sheets.Add
ActiveSheet.Name = "Tmp"
ConvertGoc2Tmp
TaoTmp
TaoRng
XuLySoCT
Sheets("Tmp").Delete
MsgBox "Cam on ban da su dung - Dien dan Giai phap Excel" & Chr(13) & Timer - Tg
With Application
.ScreenUpdating = True: .DisplayAlerts = True: .Calculation = xlCalculationAutomatic: .EnableEvents = True
Sub TaoSubRng()
With Sheets("Tmp")
If DemNo = 0 Then
Set rngNhan = .Cells(2 + dongDau, 2).Offset(DemNo, -1).Resize(DemCo, 13)
GoTo bien
If DemCo = 0 Then
Set rngCho = .Cells(2 + dongDau, 2).Offset(, -1).Resize(DemNo, 12)
GoTo bien
bien:
arrCho = rngCho.Value: arrNhan = rngNhan.Value
Sub XuLySoCT()
Dim endR&, i&
Dim Arr(), ArrSoTT()
Dim aSplit() As String
Dim SearchChar$
SearchChar = ";"
With Sheets("NKC")
endR = .Cells(RowEnd, 1).End(3).Row
Arr = .Range("B2:B" & endR).Value
ReDim ArrSoTT(1 To UBound(Arr), 1 To 1)
For i = 1 To UBound(Arr)
aSplit() = Split(Arr(i, 1), SearchChar)
Arr(i, 1) = aSplit(1)
ArrSoTT(i, 1) = i
With Sheets("NKC")
.Range("B2:B" & endR).Value = Arr
.Range("F2:F" & endR).Value = ArrSoTT
Erase Arr, ArrSoTT
Sub GanArr()
With Sheets("NKC")
.Cells(iRow, 1).Resize(SoDong, 9) = ArrKq
iRow = iRow + SoDong
Erase ArrKq
Sub TaoTmp()
With Sheets("Tmp")
endR = .Cells(RowEnd, 2).End(xlUp).Row
Arr = .Range("A2:M" & endR + 1).Value 'them +1'
endR = UBound(Arr)
ReDim ArrNo(1 To endR, 1 To 13), ArrCo(1 To endR, 1 To 13), ArrTK(1 To endR, 1 To 7)
s = 0: T = 0: u = 1
For i = 1 To endR - 1
'Gan phan no
If Arr(i, 8) <> 0 Then 'sotien no <>0
s = s + 1
For k = 1 To 4
ArrNo(s, k) = Arr(i, k)
Next k
If Arr(i, 12) <> 0 Then
For k = 10 To 11
Next k
ArrNo(s, 12) = Arr(i, 12)
ArrNo(s, 6) = Arr(i, 12) / Arr(i, 8)
ArrNo(s, 5) = "N"
ArrNo(s, 7) = CStr(Arr(i, 7)) ' & Arr(i, 5)) SHTK & CostStr
ArrNo(s, 8) = Arr(i, 8) 'so tien
ArrTK(u, 2) = ArrTK(u, 2) + 1 ' dem so N
ArrTK(u, 5) = ArrTK(u, 5) + Arr(i, 8) 'so tien N
'Gan phan co
If Arr(i, 9) <> 0 Then 'sotien co <>0
T = T + 1
For k = 1 To 4
ArrCo(T, k) = Arr(i, k)
Next k
If Arr(i, 13) <> 0 Then
For k = 10 To 11
Next k
ArrCo(T, 13) = Arr(i, 13)
ArrCo(T, 6) = Arr(i, 13) / Arr(i, 9)
ArrCo(T, 5) = "C"
ArrCo(T, 7) = CStr(Arr(i, 7)) '& Arr(i, 5)) 'SHTK & CostStr
ArrCo(T, 9) = Arr(i, 9) 'so tien
ArrTK(u, 3) = ArrTK(u, 3) + 1 ' dem so C
ArrTK(u, 6) = ArrTK(u, 6) + Arr(i, 9) 'so tien C
'tao DM TK duy nhat voi dieu kien la soct da sort******
ArrTK(u, 1) = Arr(i, 2) 'soct
ArrTK(u, 4) = Arr(i, 1) 'NgayHT
ArrTK(u, 7) = ArrTK(u, 6) - ArrTK(u, 5) 'Chenh lech
If ArrTK(u, 1) <> Arr(i + 1, 2) Then u = u + 1
'co nen gan bien dem vao
With Sheets("tmp")
.[B1] = "SoCT"
.Range("A2:M" & RowEnd).ClearContents
.Range("N2:Q" & RowEnd).ClearContents
.Range("A2").Resize(s, 13) = ArrNo
.Range("A2").Offset(s, 0).Resize(T, 13) = ArrCo
.Range("N2").Resize(u, 7) = ArrTK
Erase Arr(), ArrNo(), ArrCo(), ArrTK
With Sheets("Tmp")
endR = s + T + 1
'sort tmp
Set rngData = .Range(.Cells(1, 1), .Cells(endR, 13))
With .Sort
With .SortFields
.Clear
.Add Key:=Range("A1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayCT
.Add Key:=Range("B1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.Add Key:=Range("H1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 4 Tien No
.Add Key:=Range("I1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 5 Tien co
.SetRange rngData
.Header = xlYes ' co tieu de hay khong'
.Apply
'sort soct duy nhat
Set rngData = .Range("N2:Q" & u)
With .Sort
With .SortFields
.Clear
.Add Key:=rngData.Cells(1, 4), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayHT
.Add Key:=rngData.Cells(1, 1), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.SetRange rngData
.Header = xlNo ' co tieu de hay khong'
.Apply
Set rngData = Nothing
Sub ConvertGoc2Tmp()
Dim ArrKq()
With Sheets("NKCGoc")
Arr = .Range("A3:I" & endR).Value
ReDim ArrKq(1 To UBound(Arr), 1 To 9)
s = 0
If Len(Arr(i, 7)) > 0 Then
s = s + 1
ArrKq(s, 1) = Arr(i, 1)
ArrKq(s, 2) = Arr(i, 1) & ";" & Arr(i, 2)
ArrKq(s, 3) = Arr(i, 3)
ArrKq(s, 7) = CStr(Arr(i, 7))
ArrKq(s, 4) = Arr(i, 4)
ArrKq(s, 5) = Arr(i, 5)
ArrKq(s, 6) = Arr(i, 6)
ArrKq(s, 8) = Arr(i, 8) * 1
ArrKq(s, 9) = Arr(i, 9) * 1
With Sheets("Tmp")
.[A2].Resize(RowEnd, 9).ClearContents
.[A2].Resize(s, 9) = ArrKq
Set rngData = .Range("A2:I" & s + 1)
With .Sort
With .SortFields
.Clear
.Add Key:=rngData.Cells(1, 1), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayHT
.Add Key:=rngData.Cells(1, 2), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.Add Key:=rngData.Cells(1, 3), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 ngayCT
.SetRange rngData
.Apply
Erase Arr(), ArrKq()
Sub TaoShTmp()
With Application
With Sheets("Tmp")
.[R1] = "PSNo": .[S1] = "PSCo"
Sheets.Add
ConvertGoc2Tmp
TaoTmp
With Application
Sheets("Tmp").Select
Range("N1").Select
Private Function SheetExists(shName) As Boolean
Dim x As Object
Set x = ActiveWorkbook.Sheets(shName)
If Err = 0 Then SheetExists = True _
Else SheetExists = False
Sub TinhToan01()
'Truong hop nay danh cho 1N va 1C - Dem=2
SoDong = 1
ArrKq(SoDong, 1) = arrNhan(1, 1) 'ngay HT
ArrKq(SoDong, 2) = sSoCT 'SoCT
ArrKq(SoDong, 3) = arrNhan(1, 3) 'NgayCT
ArrKq(SoDong, 4) = arrNhan(1, 4) 'diengiai
ArrKq(SoDong, ColTkNo) = arrCho(1, 7) 'TKNo
ArrKq(SoDong, ColTkCo) = arrNhan(1, 7) 'TKCo;
ArrKq(SoDong, 7) = arrNhan(1, 9) 'sotien
If arrNhan(1, 6) > 0 Then
ArrKq(SoDong, 14) = arrNhan(1, 10) 'MaKH
ArrKq(SoDong, 15) = arrNhan(1, 11) 'TenKH
ArrKq(SoDong, 16) = Round(arrNhan(1, 6) * ArrKq(SoDong, 7), 0) 'ST VND
GanArr
Sub TinhToan05()
curCho = 0: curNhan = 0: s = 1
curSLNhanThieu = 0: curSLChoDu = 0: SLChia = 0
'Phan nay la nhieu no nhieu co
Do While Not (curCho = UBound(arrCho) And curSLChoDu = 0)
If curSLChoDu = 0 Then
curCho = curCho + 1
curSLCho = arrCho(curCho, 8)
curSLChoDu = curSLCho
If curSLNhanThieu = 0 Then
curNhan = curNhan + 1
curSLNhan = arrNhan(curNhan, 9)
curSLNhanThieu = curSLNhan
If Abs(curSLChoDu) <= Abs(curSLNhanThieu) Then
SLChia = curSLChoDu
SLChia = curSLNhanThieu
'Xem lai phan nay xu ly tru so am
ArrKq(s, 1) = arrCho(curCho, 1) 'Ngay HT
ArrKq(s, 2) = sSoCT 'SoCT
ArrKq(s, 3) = arrCho(curCho, 3) 'NgayCT
ArrKq(s, 4) = arrCho(curCho, 4) 'Dien giai
ArrKq(s, ColTkNo) = arrCho(curCho, 7) ' TK No
ArrKq(s, ColTkCo) = arrNhan(curNhan, 7) ' TK Co
ArrKq(s, 7) = SLChia 'So tien
' If arrCho(curCho, 6) > 0 Then
' ArrKQ(s, 14) = arrCho(curCho, 10) 'MaKH
' ArrKQ(s, 15) = arrCho(curCho, 11) 'TenKH
' ArrKQ(s, 16) = Round(arrCho(curCho, 6) * ArrKQ(s, 7), 0) 'ST VND
' End If
curSLChoDu = curSLChoDu - SLChia
curSLNhanThieu = curSLNhanThieu - SLChia
s = s + 1
Loop
SoDong = s - 1
GanArr
'Phan code duoi day it khi dung
Sub TinhToan06()
'With Sheets("NKC")
'Phan nay la nhieu no nhieu co vµ tat ca la so <0
curCho = curCho + 1
If curSLChoDu >= curSLNhanThieu Then 'lay so < lon hon
SLChia = curSLChoDu
If arrCho(curCho, 6) > 0 Then 'Ti gia
ArrKq(s, 14) = arrCho(curCho, 10) 'MaKH
ArrKq(s, 15) = arrCho(curCho, 11) 'TenKH
ArrKq(s, 16) = Round(ArrKq(s, 7) * arrCho(curCho, 6), 0) 'VND
s = s + 1
Loop
SoDong = s - 1
GanArr
Sub TinhToan02()
'Truong hop nay danh cho 1N va many C - Dem>2
SoDong = UBound(arrNhan)
n = 1 '1 No
For i = 1 To SoDong
For k = 1 To 4
ArrKq(i, k) = arrNhan(i, k) '4 cot dau
Next k
For k = 14 To 16
ArrKq(i, k) = arrNhan(i, k - 4) '3 cot sau
Next k
ArrKq(i, ColTkNo) = arrCho(n, 7) 'TKNo
ArrKq(i, ColTkCo) = arrNhan(i, 7) 'TKCo
ArrKq(i, 7) = arrNhan(i, 9) 'So tien
If arrNhan(i, 6) > 0 Then
ArrKq(i, 14) = arrNhan(i, 10) 'MaKH
ArrKq(i, 15) = arrNhan(i, 11) 'TenKH
ArrKq(i, 16) = Round(arrNhan(i, 6) * ArrKq(i, 7), 0) 'ST VND
GanArr
Sub TinhToan03()
'Truong hop nay danh cho 1C va many N - Dem>2
'TH nay nguoc voi TinhToan02 - be care Tuan
SoDong = UBound(arrCho)
n = 1 '1 No
For i = 1 To SoDong
For k = 1 To 4
ArrKq(i, k) = arrCho(i, k) '4 cot dau
Next k
ArrKq(i, ColTkNo) = arrCho(i, 7) 'TKNo
ArrKq(i, ColTkCo) = arrNhan(n, 7) 'TKCo
ArrKq(i, 7) = arrCho(i, 8) 'So tien
If arrCho(i, 6) > 0 Then
ArrKq(i, 14) = arrCho(i, 10) 'MaKH
ArrKq(i, 15) = arrCho(i, 11) 'TenKH
ArrKq(i, 16) = Round(arrCho(i, 6) * ArrKq(i, 7), 0) 'ST VND
GanArr
Sub TinhToan04()
' TH neu so TK No = So TK Co, STien No(1)=sotienco(1), SotienNo(end)=sotienco(end)
'MsgBox "OK"
For i = 1 To SoDong
For k = 1 To 4
Next k
GanArr
Sub TinhToan07()
' TH neu co nhieu TK No va khong co TK Co
For i = 1 To SoDong
For k = 1 To 4
Next k
For k = 10 To 3
ArrKq(i, k) = arrCho(i, k) '4 cot sau
Next k
ArrKq(i, ColTkCo) = "" 'TKCo
GanArr
Sub TinhToan08()
' TH neu co nhieu TK Co va khong co TK No
n = 1 '1 No
For i = 1 To SoDong
For k = 1 To 4
Next k
For k = 10 To 13
ArrKq(i, k) = arrNhan(i, k) '4 cot sau
Next k
ArrKq(i, ColTkNo) = "" 'arrCho(n, 7) 'TKNo
GanArr
Sub TaoSoCtNew()
Dim endR&, i&, s&, sTmp$, SoDong&
Dim Arr(), ArrKq()
With Sheets("NKC-Tmp")
endR = .Cells(RowEnd, 2).End(3).Row
Arr = .Range("A8:I" & endR).Value
s = 1: SoDong = 0
sTmp = "xxxxx"
If i > 1 Then sTmp = Arr(i - 1, 2)
If CStr(Arr(i, 2)) <> CStr(sTmp) Then SoDong = SoDong + 1
ArrKq(s, 2) = Right("0000" & SoDong, 5) & ";" & Arr(i, 2)
s = s + 1
If s Then
.Range("A3:I" & endR).ClearContents
.[A3].Resize(s, 9) = ArrKq
Cảm ơn bạn rất nhiều!!!
