Phương Phương mito
Thử code này.Kính gửi anh chị,
Em có nội dung tại cột A, mỗi ô gồm 2 dòng (xuống dòng bằng Alt+Enter). Code VBA làm sao để tách 2 dòng này ra cột B và C ạ. Em cảm ơn.
Sub tach()
Dim i As Long, lr As Long, arr, kq, T
With Sheets("sheet1")
lr = .Range("A" & Rows.Count).End(xlUp).Row
arr = .Range("A2:B" & lr).Value
ReDim kq(1 To UBound(arr), 1 To 2)
For i = 1 To UBound(arr)
T = Split(arr(i, 1), Chr(10))
If UBound(T) > 0 Then
kq(i, 1) = T(0)
kq(i, 2) = T(1)
.Range("B2:C" & lr).Value = kq
Sub chiaLy(byval rng as range)
Dim sDeli as string, data as variant, i as long, sText as string
Dim a as variant, res as variant
sDeli = vba.chr$(10)
data = rng.resize(rng.rows.count + 1).value2
redim res(1 to ubound(data,1)-1, 1 to 2)
for i=1 to ubound(data,1)-1
sText = data(i,1)
sText = vba.replace(sText, "'", "")
a = vba.split(sText, sDeli)
res(i,1)= vba.trim$(a(0))
if vba.instr(1, sText, sDeli)>0 then res(i,2) = vba.trim$(a(1))
next i
rng.cells(1,1).offset(0,1).resize(ubound(res,1), ubound(res,2)).value=res
erase data, res
end sub
Code chạy đúng rồi, em cảm ơn anh nhiều ạ !Thử code này.
Mã:Sub tach() Dim i As Long, lr As Long, arr, kq, T With Sheets("sheet1") lr = .Range("A" & Rows.Count).End(xlUp).Row arr = .Range("A2:B" & lr).Value ReDim kq(1 To UBound(arr), 1 To 2) For i = 1 To UBound(arr) T = Split(arr(i, 1), Chr(10)) If UBound(T) > 0 Then kq(i, 1) = T(0) kq(i, 2) = T(1) End If Next i .Range("B2:C" & lr).Value = kq End With End Sub
Cảm ơn anh đã hỗ trợ em ạ !PHP:Sub chiaLy(byval rng as range) Dim sDeli as string, data as variant, i as long, sText as string Dim a as variant, res as variant sDeli = vba.chr$(10) data = rng.resize(rng.rows.count + 1).value2 redim res(1 to ubound(data,1)-1, 1 to 2) for i=1 to ubound(data,1)-1 sText = data(i,1) sText = vba.replace(sText, "'", "") a = vba.split(sText, sDeli) res(i,1)= vba.trim$(a(0)) if vba.instr(1, sText, sDeli)>0 then res(i,2) = vba.trim$(a(1)) next i rng.cells(1,1).offset(0,1).resize(ubound(res,1), ubound(res,2)).value=res erase data, res end sub
Function TachTrai(Rng As String) As String
TachTrai = Split(Rng, Chr(10))(0)
Function TachPhai(Rng As String) As String
TachPhai = Split(Rng, Chr(10))(1)
Món này là em học lỏm, cứ thấy ra kết quả là mừng lắm rồi (hay dùng để tách ký tự đặc biệt).Cần bẫy lỗi trường hợp không có char(10) chứ.
Hoặc chí ít không có char(10) thì vẫn phải trả về kết quả chứ.
