Em bị array is fixed or temorary locked giúp em với! (3 người xem)
tukut3boyhp9x
Code em viết đây ạ sau khi chạy đến lặp lần 2 thì bị vấn đề như nay ạ
Em đã cố thử dùng cách redim ma không được ạ
đây la bị sao vậy ạ
Sub Perm()
Dim chuoi1 As Variant
Dim dk1 As Variant
Dim vitria As Integer
Dim chuoia As Variant
Dim s1 As Variant
Dim dk As Variant
Dim s2 As Variant
Dim s3 As Variant
Dim s4 As Variant
Dim s1a As Variant
Dim s2a As Variant
Dim s3a As Variant
Dim s4a As Variant
Dim dem As Long
Dim demsodong As Long
Dim sodong As Integer
Dim sokq As Integer
Dim giai As Integer
sodong = InputBox("Bac dien tong so dong bac muon thuc hien", "So dong thuc hien", "100")
sokq = InputBox("Bac muon chuyen tu bo 4(so) hay bo 5(so)", "Bo so bao nhieu?", "4")
giai = InputBox("Nhap so giai bac muon choi (45 hoac 55)", "Giai tham gia", "45")
dem = 1
vitria = 2
Range("h1:K4").EntireColumn.Insert
Range("A1:b1").EntireColumn.Insert
If giai = 55 Then
chuoi1 = Array(1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55)
If giai = 45 Then
s1 = Range("C4:C104").Value
s2 = Range("D4:D104").Value
s3 = Range("E4:E104").Value
s4 = Range("F4:F104").Value
Range("A1").Value = "a"
Range("B1").Value = "b"
Range("G2").Clear 'don o a
chuoi1 = Array(1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45)
Range("B2").Value = "=COUNTIF(A2,$C$2)+COUNTIF(A2,$D$2)+COUNTIF(A2,$E$2)+COUNTIF(A2,$F$2)+COUNTIF(A2,$G$2)"
Range("A2:A46").Value = Application.WorksheetFunction.Transpose(chuoi1)
Range("B2:B46").FillDown
For Each s1a In s1
    For Each s2a In s2
        For Each s3a In s3
            For Each s4a In s4
    Range("F2").Value = s4a
    Range("E2").Value = s3a
    Range("D2").Value = s2a
    Range("C2").Value = s1a
    Range("$B$1:$B$46").AutoFilter Field:=1, Criteria1:="0"
    Range("A2:A46").Copy
    Range("A47").Select
    ActiveSheet.Paste
    Columns("B:B").AutoFilter
    dk = Range("A47:A86").Value
    Range("A47:A87").Clear
    For Each chuoia In dk
    dem = dem + 1
    Range("$G$2") = chuoia
Range("A47").Select
ActiveSheet.Paste
dk1 = Range("A47:A86").Value
    Range("A47:A86").Clear
    'dua ra ket qua
    Range(Cells(vitria, 10), Cells(vitria + 39, 10)).Value = s1a
    Range(Cells(vitria, 11), Cells(vitria + 39, 11)).Value = s2a
    Range(Cells(vitria, 12), Cells(vitria + 39, 12)).Value = s3a
    Range(Cells(vitria, 13), Cells(vitria + 39, 13)).Value = s4a
    Range(Cells(vitria, 14), Cells(vitria + 39, 14)).Value = chuoia
    Range(Cells(vitria, 15), Cells(vitria + 39, 15)).Value = dk1
    vitria = vitria + 40
    If dem = 42 Then
    demsodong = demsodong + 1
    Range("I1").EntireColumn.Insert
    dem = 1
    vitria = 2
        If demsodong = sodong + 1 Then
        Range("A1").EntireColumn.Delete
        GoTo ketthuc
    GoTo dongmoi
    Next chuoia
            Next s4a
        Next s3a
    Next s2a
dongmoi: Next s1a
ketthuc: End Sub
đây la bị sao vậy ạ
Sub Perm()
Dim dk1 As Variant
Dim s1 As Variant
Dim dk As Variant
Dim s2 As Variant
Dim s3 As Variant
Dim s4 As Variant
Dim s1a As Variant
Dim s2a As Variant
Dim s3a As Variant
Dim s4a As Variant
Dim dem As Long
Dim sokq As Integer
Dim giai As Integer
dem = 1
vitria = 2
If giai = 55 Then
If giai = 45 Then
For Each s1a In s1
    For Each s2a In s2
        For Each s3a In s3
            For Each s4a In s4
    Range("A47").Select
    ActiveSheet.Paste
    dem = dem + 1
Range("A47").Select
ActiveSheet.Paste
    'dua ra ket qua
    If dem = 42 Then
    dem = 1
    vitria = 2
        GoTo ketthuc
    GoTo dongmoi
    Next chuoia
            Next s4a
        Next s3a
    Next s2a
dongmoi: Next s1a
ketthuc: End Sub
Bạn post bài mà không kèm theo file thì rất bất tiện cho việc giúp đỡ cho bạn quá!
Bác ơi em gửi file với ạ
-Lỗi bị tại array dk = Range("A47:A86").Value sau khi em đưa từ hàng goto dongmoi để đến vòng thứ 2 ạ
-Với cả cho em hỏi la tại sao khi em bị lỗi khi ở vong lặp 2 số s4a của em vẫn là số cũ ạ
em cảm ơn
Để duyệt mảng dk thì duyệt theo chỉ số dòng lá sẽ chạy mượt
Upvote 1
Giải pháp
