quyenpv
Thu nhặt kiến thức
- Giới tính
- Nam
- Nghề nghiệp
- Decode cuộc đời!
Dear anh chị
Nhờ anh chị Fix lỗi muốn Copy tiêu đề từ file nguồn sang Workbook mới bị lỗi
Sub CV_ChuaHoanThanh()
ActiveWorkbook.Sheets("Data").Select
Dim lr As Long
Dim lrLoc As Long
Dim sRootFolder, sFolder_Unfinished As String
Dim sDauky, sCuoiky
sRootFolder = ActiveWorkbook.Sheets("Setting").Range("K8")
sFolder_Unfinished = ActiveWorkbook.Sheets("Setting").Range("K10")
sDauky = Format(ActiveWorkbook.Sheets("Report").Range("Dauky"), "dd-mm-yyyy")
sCuoiky = Format(ActiveWorkbook.Sheets("Report").Range("cuoiky"), "dd-mm-yyyy")
Dim filename As Workbook
If Len(Dir(sRootFolder & "\" & sFolder_Unfinished, vbDirectory)) = 0 Then
MkDir (sRootFolder & "\" & sFolder_Unfinished)
ActiveWorkbook.Sheets("Data").Range("A5:O5").Copy
StopCalc
Dim i&, k, Data(), Kq(), Sort(), lastRow
Data = Range(Sheets("Data").[A6], Sheets("Data").[A10000].End(3)).Resize(, 15)
ReDim Kq(1 To UBound(Data), 1 To 15)
For i = 1 To UBound(Data)
If Data(i, 11) <> "" And Data(i, 11) <> ActiveWorkbook.Sheets("Setting").Range("I2") Then
Kq(k, 1) = k: Kq(k, 2) = Data(i, 2)
Kq(k, 3) = Data(i, 3): Kq(k, 4) = Data(i, 4)
Kq(k, 5) = Data(i, 5): Kq(k, 6) = Data(i, 6)
Kq(k, 7) = Data(i, 7): Kq(k, 8) = Data(i, 8)
Kq(k, 9) = Data(i, 9): Kq(k, 10) = Data(i, 10)
Kq(k, 11) = Data(i, 11): Kq(k, 12) = Data(i, 12)
Kq(k, 13) = Data(i, 13): Kq(k, 14) = Data(i, 14)
Kq(k, 15) = Data(i, 15)
Set filename = Workbooks.Add
Range("A5").Select
ActiveSheet.Paste
With filename.Worksheets("Sheet1")
.Range("A6").Resize(k, 15).Value = Kq
.Range("D6:d" & 6 + k).WrapText = 1
.Columns("B:B").NumberFormat = "dd/mm"
.Columns("D:D").ColumnWidth = 53
.Columns("G:G").NumberFormat = "dd/mm"
.Columns("J:J").Style = "Percent"
' filename.Worksheets("Sheet1").Rows(1, 99999).Autofit
filename.SaveAs filename:=sRootFolder & "\" & sFolder_Unfinished & "\" & "Cong Viec Chua Hoan Thanh tu " & sDauky & " den " & sCuoiky
'ActiveWorkbook.Close
ResetCalc
'End If
