Public Sub ListFilesOrFolders(ByVal FolderStart As String, result, Optional sFilter As String = "", _
Optional folder As Boolean = False, Optional inSub As Boolean = False, Optional NameOnly As Boolean = True)
' Neu lay tat ca cac tap tin hoac thu muc thi nhap sFilter = "" (da la mac dinh nen co the bo qua)
' Neu lay tat ca cac tap tin vd. co dang JPG thi sFilter = "*.jpg",
' Neu lay tat ca cac tap tin JPG ma ten phai chua hichic thi sFilter = "*hichic*.jpg"
' Neu muon tim ca o cac thu muc con thi inSub = TRUE, nguoc lai thi inSub = FALSE (mac dinh)
' Neu chi lay ten thi NameOnly = True (mac dinh). Neu muon lay toan bo duong dan thi NameOnly = FALSE.
' Neu tim tap tin thi folder = False (mac dinh). Neu tim thu muc thi folder = True.
' Ham bat dau tim trong thu muc khoi dong FolderStart
' Ket qua tim kiem duoc tra ve trong mang result co chi so tinh tu 1
Dim count As Long, f As Object, fso As Object, SubF As Object, files As Object
If fso.FolderExists(FolderStart) Then
If sFilter = "" Then sFilter = "*"
Set f = fso.GetFolder(FolderStart)
count = f.files.count
If Err.Number Then
Err.Clear
On Error GoTo 0
On Error GoTo 0
Set files = IIf(folder, f.SubFolders, f.files)
For Each SubF In files
If LCase(SubF.Name) Like LCase(sFilter) Then
If IsEmpty(result) Then
ReDim result(1 To 1)
count = 0
count = UBound(result)
ReDim Preserve result(1 To count + 1)
If NameOnly Then
result(UBound(result)) = SubF.Name
result(UBound(result)) = SubF.Path
If inSub And folder Then
ListFilesOrFolders SubF.Path, result, sFilter, True, True, NameOnly
Next SubF
If inSub And Not folder Then
For Each SubF In f.SubFolders
ListFilesOrFolders SubF.Path, result, sFilter, False, True, NameOnly
Set f = Nothing
Set fso = Nothing
' Các ví dụ dùng
Sub test1()
Dim result, k As Long
' tất cả tập tin trong thư mục "c:\1" và các thư mục con, chỉ tên thôi
ListFilesOrFolders "c:\1", result, "", , True
If Not IsEmpty(result) Then
For k = 1 To UBound(result)
Debug.Print result(k)
Next k
Sub test2()
' tất cả tập tin trong thư mục "c:\1", chỉ tên thôi
Next k
Sub test3()
' tất cả thư mục trong thư mục "c:\1", chỉ tên thôi
ListFilesOrFolders "c:\1", result, "", True
Next k
Sub test4()
' tất cả thư mục trong thư mục "c:\1" và các thư mục con, chỉ tên thôi
ListFilesOrFolders "c:\1", result, "", True, True
Next k
