VBA xóa dòng tiêu đề (1 người xem)
sai_hikaru5555
Sub TachNhom()
Dim myCell As Range
    Dim wks As Worksheet
    Dim DataBaseWks As Worksheet
    Dim ListRange As Range
    Dim dummyRng As Range
    Dim myDatabase As Range
    Dim TempWks As Worksheet
    Dim rsp As Integer
    Dim i As Long
‘chinh dau tieu de
    Const TopLeftCellOfDataBase As String = "A1"
‘chinh cot lay du lieu
Const KeyColumn As String = "A"
    Set DataBaseWks = Worksheets("DATA")
    i = DataBaseWks.Range(TopLeftCellOfDataBase).Row - 1
    Set TempWks = Worksheets.Add
    With DataBaseWks
        Set dummyRng = .UsedRange
        Set myDatabase = .Range(TopLeftCellOfDataBase, _
                            .Cells.SpecialCells(xlCellTypeLastCell))
    With DataBaseWks
        Intersect(myDatabase, .Columns(KeyColumn)).AdvancedFilter _
            Action:=xlFilterCopy, _
            CopyToRange:=TempWks.Range("A1"), _
            Unique:=True
        TempWks.Range("D1").Value = _
            .Cells(.Range(TopLeftCellOfDataBase).Row, KeyColumn).Value
    With TempWks
        Set ListRange = .Range("A2", .Cells(.Rows.Count, "A").End(xlUp))
    With ListRange
        .Sort Key1:=.Cells(1), Order1:=xlAscending, _
            Header:=xlNo, OrderCustom:=1, _
            MatchCase:=False, Orientation:=xlTopToBottom
    For Each myCell In ListRange.Cells
        If WksExists(myCell.Value) = False Then
            Set wks = Sheets.Add
            wks.Name = myCell.Value
            If Err.Number <> 0 Then
                MsgBox "Please rename: " & wks.Name
                Err.Clear
            On Error GoTo 0
            wks.Move After:=Sheets(Sheets.Count)
            Set wks = Worksheets(myCell.Value)
            wks.Cells.Clear
        If rsp = 6 Then
          DataBaseWks.Rows("1:" & i).Copy Destination:=wks.Range("A1")
        TempWks.Range("D2").Value = "=" & Chr(34) & "=" & myCell.Value & Chr(34)
        If rsp = 6 Then
          myDatabase.AdvancedFilter _
              CriteriaRange:=TempWks.Range("D1:D2"), _
              CopyToRange:=wks.Range("A1").Offset(i, 0), _
              Unique:=False
              CopyToRange:=wks.Range("A1"), _
              Unique:=False
              Columns("D:D").ColumnWidth = 20
              Columns("F:F").ColumnWidth = 20
              Columns("G:G").ColumnWidth = 15
    Next myCell
    'Sub tachsheet()
Dim sh As Worksheet
For Each sh In Worksheets
    sh.Copy
    ActiveWorkbook.SaveAs ThisWorkbook.Path & "\" & sh.Name, 51
    ActiveWorkbook.Close
'Application.ScreenUpdating = True
'Application.DisplayAlerts = True
'End Sub
    TempWks.Delete
    MsgBox "TÁCH  PL THANH CONG"
Function WksExists(wksName As String) As Boolean
    WksExists = CBool(Len(Worksheets(wksName).Name) > 0)
Mình có 1 file dữ liệu cần tách ra thành nhiều sheet ( theo cột A) và delete dòng tiêu đề. VBA dưới đây mình đã tách được các sheet thành từng fie rồi, còn phần delete dòng tiêu đề thì mình chưa làm được. Xin các cao nhân chỉ giáo giúp mình nhé. Thanks all!
Sub TachNhom()
Dim myCell As Range
    Dim rsp As Integer
    Dim i As Long
‘chinh dau tieu de
    With DataBaseWks
    With DataBaseWks
            Unique:=True
    With TempWks
    With ListRange
                Err.Clear
            On Error GoTo 0
            wks.Cells.Clear
        If rsp = 6 Then
        If rsp = 6 Then
              Unique:=False
              Unique:=False
    Next myCell
    'Sub tachsheet()
Dim sh As Worksheet
    sh.Copy
'End Sub
    TempWks.Delete
Mình có 1 file dữ liệu cần tách ra thành nhiều sheet ( theo cột A) và delete dòng tiêu đề. VBA dưới đây mình đã tách được các sheet thành từng fie rồi, còn phần delete dòng tiêu đề thì mình chưa làm được. Xin các cao nhân chỉ giáo giúp mình nhé. Cảm ơn all!
Bạn muốn tách thành sheet hay là tách thành workbook mới thế
Bạn viết được đoạn code đó mà không biết xóa dòng tiêu đề như thế nào à???
Cái này là chị sếp cũ của mình viết, sử dụng trước giờ, những bây giờ mình cần delete dòng mà không biết làm sao.
Cái này là tách thành từng workbook bạn ạ. Mà cái mình cần là khi tách từng workbook thì nó tự động delete dòng tiêu đề trong workbook đó luôn.
Vậy là chỉ lấy dữ liệu ở trong thôi à. Chứ ko cần tiêu đề
Cái này chủ Top muốn theo Code cũ thì để xoá dòng đầu thêm wks.Rows("1").Delete sau khi copy từng range qua
TempWks.Delete xoá Sheet tạm thì dời lên phí trên code tách Sheet
if sh.Name <>"data" then
'do somthing
end if
Đưa 2 cái này lên đầu sub
Ban thử code này. Code tham khảo trên diễn đàn không nhớ đường dẫn nguồn
Sub ABC()
    Dim Dic As Object, Vung As Range, wbMoi As Workbook
    Dim Arr, n&, iRow&
    Dim sFolder$, TenFile$, TenSheet$
sFolder = ThisWorkbook.Path & "\"
iRow = ThisWorkbook.Worksheets("data").Range("A" & Rows.Count).End(xlUp).Row
Set Vung = ThisWorkbook.Worksheets("data").Range("A1:G" & iRow)
Arr = Vung.Offset(1).Columns("A:A").Value
Vung.Range("IV1").Value = Vung.Range("A1").Value
For n = 1 To UBound(Arr)
    If Len(Arr(n, 1)) Then
        TenSheet = Arr(n, 1):  TenFile = Arr(n, 1)
        If Not Dic.Exists(TenSheet) Then
            Dic.Add TenSheet, Empty
            Set wbMoi = Workbooks.Add(1)
            wbMoi.Sheets(1).Name = TenSheet
            Vung.Range("IV2").Value = "'=" & TenSheet
            Vung.AdvancedFilter 2, Vung.Range("IV1:IV2"), wbMoi.Sheets(1).Range("A1")
            wbMoi.Sheets(1).Rows("1").Delete
            wbMoi.SaveAs sFolder & TenFile, xlOpenXMLWorkbook
            wbMoi.Close True
Vung.Range("IV1:IV2").ClearContents
If Dic.Count Then MsgBox "Ða tach File xong", , "THÔNG BÁO"
Còn dùng code cũ thì như anh thuyyeu99 gợi ý cũng được
Lâu ngày mới thấy code viết đẹp vậy.
Lối viết rất chững chạc rành mạch. Đặt tên biến cũng chuẩn.
Chỉ tiếc là lúc gom cái Sub tachSheet() vào thì làm cẩu thả. Đọc như đang ăn bữa ăn ngon là bị món tráng miệng nó cháy khét.
(chỉ nói về cái nhìn thôi, chứ chưa tính đến hiệu dụng)
Sub ABC()
    Dim Arr, n&, iRow&
            wbMoi.Close True
Mình làm được rồi nhé. Cám ơn bạn.
'do somthing
end if
Mình làm được rồi nhé. Cám ơn bạn!
