Sửa Macro thành Code để tự chạy
Mình có ghi lại cái Macro nối cột như bài đã nêu ở trên,nhưng lại muốn cho nó tự động chạy và trong điều
kiện là hai Sheet này đều ẩn,Các bạn giúp mình nhé,Cảm ơn các bạn.
Code:
Sub Macro5()
' Macro5 Macro
' Macro recorded 4/26/2011 by win7
Range("A1:A5").Select
Selection.copy
Sheets("Sheet3").Select
Range("A1").Select
ActiveSheet.Paste Link:=True
Sheets("Sheet2").Select
Range("B1:B5").Select
Selection.copy
Range("A6").Select
Range("C1:C5").Select
Selection.copy
Range("A11").Select
Range("D1
5").Select
Selection.copy
Range("A16").Select
Range("E1:E5").Select
Selection.copy
ActiveWindow.SmallScroll Down:=12
Range("A21").Select
Range("F1:F5").Select
Selection.copy
Range("A26").Select
Range("G1:G5").Select
Selection.copy
Range("A31").Select
Range("H1:H5").Select
Selection.copy
Range("A36").Select
Range("I1:I5").Select
Selection.copy
ActiveWindow.SmallScroll Down:=9
Range("A41").Select
Range("J1:J5").Select
Selection.copy
Range("A46").Select
ActiveWindow.SmallScroll Down:=-6
Range("K1").Select
ActiveCell.FormulaR1C1 = ""
Range("K1").Select
