Giúp em công thức tính tổng trong kho, ko dùng Countif ạ (6 người xem)
Thử vầy xem sao!?
C2=IF(B2>0,TEXT(COUNTIF($B$2:$B$10000,B2),"[>2];;\0"),)
Enter, fill xuống.
Dạ em CT này cho kết quả dạng text, em dùng tiếp CT khác cho kết quả này bị cho ra kết quả sai, nhờ anh sửa giúp em kết quả hiển thị ko fai là text với ạ, em cảm ơn anh !
Thêm -- trước If()
C2=--IF(B2>0,TEXT(COUNTIF($B$2:$B$10000,B2),"[>2];;\0"),)
Dạ nhờ anh hướng dẫn cách chạy với ạ !
Support page
DCOUNTA function​
This article describes the formula syntax and usage of the DCOUNTA function in Microsoft Excel.
Description​
Counts the nonblank cells in a field (column) of records in a list or database that match conditions that you specify.
The field argument is optional. If field is omitted, DCOUNTA counts all records in the database that match the criteria.
Syntax​
DCOUNTA(database, field, criteria)
The DCOUNTA function syntax has the following arguments:
  • Database Required. The range of cells that makes up the list or database. A database is a list of related data in which rows of related information are records, and columns of data are fields. The first row of the list contains labels for each column.
  • Field Optional. Indicates which column is used in the function. Enter the column label enclosed between double quotation marks, such as "Age" or "Yield," or a number (without quotation marks) that represents the position of the column within the list: 1 for the first column, 2 for the second column, and so on.
  • Criteria Required. The range of cells that contains the conditions that you specify. You can use any range for the criteria argument, as long as it includes at least one column label and at least one cell below the column label in which you specify a condition for the column.
  • Remarks
  • You can use any range for the criteria argument, as long as it includes at least one column label and at least one cell below the column label for specifying the condition.
    For example, if the range G1:G2 contains the column label Income in G1 and the amount $10,000 in G2, you could define the range as MatchIncome and use that name as the criteria argument in the database functions.
  • Although the criteria range can be located anywhere on the worksheet, do not place the criteria range below the list. If you add more information to the list, the new information is added to the first row below the list. If the row below the list is not blank, Excel cannot add the new information.
  • Make sure that the criteria range does not overlap the list.
  • To perform an operation on an entire column in a database, enter a blank line below the column labels in the criteria range.
Support page
DCOUNTA function​
Description​
Syntax​
  • Remarks
Dạ vậy chạy bằng VBA ak anh, tại em ko rành anh thông cảm cho em.
Đó là hàm cổ lỗ sỹ của Ecxel mà, trời đất!
→ → → → → → Help
