Function CatTen(str As String, ch As String) As String
Dim mlen As Long
Dim i As Long
mlen = Len(str)
For i = mlen To 1 Step -1
If Mid(str, i, 1) = ch Then
Exit For
If i <> 0 Then
CatTen = Trim(Mid(str, i + 1, mlen - i))
CatTen = Trim(str)
Function CatHo(str As String, ch As String) As String
Dim mlen As Long
Dim i As Long
mlen = Len(str)
For i = 1 To mlen
Exit For
If i <> 0 Then
CatHo = Trim(Mid(str, 1, i - 1))
CatHo = Trim(str)
Function LayTF(st As String)
Dim s As String
s = CatTen(st, "\")
s = CatHo(s, ".")
LayTF = s
Function ConvertToUnSign(ByVal sContent As String) As String
Dim i As Long
Dim intCode As Long
Dim sChar As String
Dim sConvert As String
ConvertToUnSign = AscW(sContent)
For i = 1 To Len(sContent)
sChar = Mid(sContent, i, 1)
If sChar <> "" Then
intCode = AscW(sChar)
Select Case intCode
Case 273
sConvert = sConvert & "d"
Case 272
sConvert = sConvert & "D"
Case 224, 225, 226, 227, 259, 7841, 7843, 7845, 7847, 7849, 7851, 7853, 7855, 7857, 7859, 7861, 7863
sConvert = sConvert & "a"
Case 192, 193, 194, 195, 258, 7840, 7842, 7844, 7846, 7848, 7850, 7852, 7854, 7856, 7858, 7860, 7862
sConvert = sConvert & "A"
Case 232, 233, 234, 7865, 7867, 7869, 7871, 7873, 7875, 7877, 7879
sConvert = sConvert & "e"
Case 200, 201, 202, 7864, 7866, 7868, 7870, 7872, 7874, 7876, 7878
sConvert = sConvert & "E"
Case 236, 237, 297, 7881, 7883
sConvert = sConvert & "i"
Case 204, 205, 296, 7880, 7882
sConvert = sConvert & "I"
Case 242, 243, 244, 245, 417, 7885, 7887, 7889, 7891, 7893, 7895, 7897, 7899, 7901, 7903, 7905, 7907
sConvert = sConvert & "o"
Case 210, 211, 212, 213, 416, 7884, 7886, 7888, 7890, 7892, 7894, 7896, 7898, 7900, 7902, 7904, 7906
sConvert = sConvert & "O"
Case 249, 250, 361, 432, 7909, 7911, 7913, 7915, 7917, 7919, 7921
sConvert = sConvert & "u"
Case 217, 218, 360, 431, 7908, 7910, 7912, 7914, 7916, 7918, 7920
sConvert = sConvert & "U"
Case 253, 7923, 7925, 7927, 7929
sConvert = sConvert & "y"
Case 221, 7922, 7924, 7926, 7928
sConvert = sConvert & "Y"
Case Else
sConvert = sConvert & sChar
End Select
ConvertToUnSign = sConvert
Function UniVba(TxtUni As String) As String
If TxtUni = "" Then
UniVba = ""
TxtUni = TxtUni & " "
'If AscW(Left(TxtUni, 1)) < 256 Then UniVba = """"
For n = 1 To Len(TxtUni) - 1
uni1 = Mid(TxtUni, n, 1)
uni2 = AscW(Mid(TxtUni, n + 1, 1))
If AscW(uni1) > 255 And uni2 > 255 Then
'UniVba = UniVba & "ChrW(" & AscW(uni1) & ") & "
UniVba = UniVba & "&#" & AscW(uni1) & ";"
ElseIf AscW(uni1) > 255 And uni2 < 256 Then
'UniVba = UniVba & "ChrW(" & AscW(uni1) & ") & """
ElseIf AscW(uni1) < 256 And uni2 > 255 Then
'UniVba = UniVba & uni1 & """ & "
If Right(UniVba, 4) = " & """ Then
UniVba = Mid(UniVba, 1, Len(UniVba) - 4)
'UniVba = UniVba & """"
UniVba = UniVba
Sub KML_converter()
Dim password As Variant
password = Application.InputBox("Enter Password- Nguyen Gia Thanh", "Password Protected")
Select Case password
Case Is = False
MsgBox "Chua nhap mat ma, khong the dang nhap chuong trinh..."
ThisWorkbook.Close False
'do nothing
Case Is = "123456789"
MsgBox "Dang nhap thanh cong! ", , "Thông báo"
Case Else
MsgBox "Mat ma sai, khong the dang nhap chuong trinh..."
End Select
Dim lOutputFile As Long
Dim sitename, BD As Range
Dim header As Range
Dim layername, st, Folder As String
Dim Filename As String
Dim i, j, nameOffset, LongOffset, LatOffset, ColorOffsetAs, XaOffset As Integer
Dim Socot As Integer
Dim Cot(100) As String
Dim Mau(5)
Mau(0) = ThisWorkbook.Worksheets("QuyDinhMau").Range("C2").Value
Mau(1) = ThisWorkbook.Worksheets("QuyDinhMau").Range("C3").Value
Mau(2) = ThisWorkbook.Worksheets("QuyDinhMau").Range("C4").Value
Mau(3) = ThisWorkbook.Worksheets("QuyDinhMau").Range("C5").Value
Mau(4) = ThisWorkbook.Worksheets("QuyDinhMau").Range("C6").Value
Set BD = ThisWorkbook.Worksheets("Mau_KML").Range("A1")
Set sitename = ThisWorkbook.Worksheets(1).Range("A5")
Set header = ThisWorkbook.Worksheets(1).Range("A4")
' Get a valid file number
lOutputFile = FreeFile
' Create a new file for output
'Filename = Left(ThisWorkbook.Name, InStr(ThisWorkbook.Name, ".") - 1) & ".kml"
Filename = WorksheetFunction.Substitute(ConvertToUnSign(sitename.Offset(1, 5).Value), " ", "_") & "_" & Format(Now(), "yyyy_mm_dd") + ".kml"
fileSaveName = Application.GetSaveAsFilename( _
InitialFileName:=Filename, _
fileFilter:="KML Files (*.kml), *.kml")
Open fileSaveName For Output As #lOutputFile
' Loop until there isn't any data in the first column
'layername = InputBox("Nhap ten layer name trong Google Earth")
i = 0
Do While (header.Offset(0, i).Value <> "")
'MsgBox UniVba(header.Offset(0, i).Value)
Cot(i) = UniVba(header.Offset(0, i).Value)
If UCase(Cot(i)) = "U" Then nameOffset = i
If UCase(Cot(i)) = "LONGITUDE" Then LongOffset = i
If UCase(Cot(i)) = "LATITUDE" Then LatOffset = i
If UCase(Cot(i)) = "COLOR" Then ColorOffset = i
If UCase(Cot(i)) = "CCAO" Then XaOffset = i
Socot = i
i = i + 1
Loop
'MsgBox (nameOffset)
'MsgBox (LongOffset)
'MsgBox (LatOffset)
'Print #lOutputFile, "<?xml version='1.0' encoding='UTF-8'?>"
'Print #lOutputFile, "<kml>"
Print #lOutputFile, "<Document>"
Print #lOutputFile, "<name>" & LayTF(Filename) & "</name>"
For i = 0 To 4
For j = 0 To 33
If j = 0 Or j = 3 Or j = 7 Or j = 10 Or j = 22 Then
st = BD.Offset(j, 0).Value & Trim(str(i + 1)) & BD.Offset(j, 2).Value
If j = 14 Or j = 26 Then
st = BD.Offset(j, 0).Value & Mau(i) & BD.Offset(j, 2).Value
st = BD.Offset(j, 0).Value & BD.Offset(j, 1).Value & BD.Offset(j, 2).Value
Print #lOutputFile, st
layername = UniVba(Trim(sitename.Offset(0, XaOffset).Value))
Print #lOutputFile, "<Folder>"
Print #lOutputFile, "<name>" & layername & "</name>"
Do While (sitename.Value <> "")
If layername <> UniVba(Trim(sitename.Offset(0, XaOffset).Value)) Then
Print #lOutputFile, "</Folder>"
Print #lOutputFile, "<Placemark>"
Print #lOutputFile, sitename.Offset(0, nameOffset).Value
Print #lOutputFile, "</name>"
Print #lOutputFile, "<description>"
Print #lOutputFile, "<![CDATA[<br><br><br>"
Print #lOutputFile, "<table border="; 1; " padding="; 0; ">"
For i = 0 To Socot
Print #lOutputFile, "<tr><td>" & Cot(i) & "</td><td>" & UniVba(sitename.Offset(0, i).Value) & "</td></tr>"
Print #lOutputFile, "</table>"
Print #lOutputFile, "]]>"
'Print #lOutputFile, header.Value & ": " & sitename.Offset(0, 3).Value
'Print #lOutputFile, header.Offset(0, 1).Value & ": " & sitename.Offset(0, 4).Value
'Print #lOutputFile, header.Offset(0, 2).Value & ": " & sitename.Offset(0, 5).Value
'Print #lOutputFile, header.Offset(0, 3).Value & ": " & sitename.Offset(0, 6).Value
'Print #lOutputFile, header.Offset(0, 4).Value & ": " & sitename.Offset(0, 7).Value
'Print #lOutputFile, header.Offset(0, 5).Value & ": " & sitename.Offset(0, 8).Value
'Print #lOutputFile, header.Offset(0, 6).Value & ": " & sitename.Offset(0, 9).Value
'Print #lOutputFile, header.Offset(0, 7).Value & ": " & sitename.Offset(0, 10).Value
'Print #lOutputFile, header.Offset(0, 8).Value & ": " & sitename.Offset(0, 11).Value
'Print #lOutputFile, header.Offset(0, 9).Value & ": " & sitename.Offset(0, 12).Value
'Print #lOutputFile, header.Offset(0, 10).Value & ": " & sitename.Offset(0, 13).Value
'Print #lOutputFile, header.Offset(0, 11).Value & ": " & sitename.Offset(0, 14).Value
'Print #lOutputFile, header.Offset(0, 12).Value & ": " & sitename.Offset(0, 15).Value
Print #lOutputFile, "</description>"
Print #lOutputFile, "<LookAt>"
Print #lOutputFile, "<longitude>" & sitename.Offset(0, LongOffset).Value & "</longitude>"
Print #lOutputFile, "<latitude>" & sitename.Offset(0, LatOffset).Value & "</latitude>"
'Print #lOutputFile, "<range>1000</range>"
'Print #lOutputFile, "<Style><LineStyle><color>FF00FF00</color><width>2</width></LineStyle></Style>"
'Print #lOutputFile, "<LineString><tessellate>1</tessellate>"
'Print #lOutputFile, "<coordinates>"
Print #lOutputFile, "<visibility>1</visibility>"
Print #lOutputFile, "<open>0</open>"
Print #lOutputFile, "<tilt>0</tilt>"
Print #lOutputFile, "<heading>0</heading>"
Print #lOutputFile, "</LookAt>"
Print #lOutputFile, "<styleUrl>" & sitename.Offset(0, ColorOffset).Value & "</styleUrl>"
Print #lOutputFile, "<Point>"
Print #lOutputFile, "<extrude>1</extrude>"
Print #lOutputFile, "<altitudeMode>relativeToGround</altitudeMode>"
Print #lOutputFile, "<coordinates>" & sitename.Offset(0, LongOffset).Value & "," & sitename.Offset(0, LatOffset).Value & ",0</coordinates>"
Print #lOutputFile, "</Point>"
Print #lOutputFile, "</Placemark>"
Set sitename = sitename.Offset(1, 0)
Loop
Print #lOutputFile, "</Document>"
Print #lOutputFile, "</kml>"
Close lOutputFile
MsgBox ("Da chuyen doi xong !")
Sub t()
MsgBox (WorksheetFunction.Substitute("A B", " ", "_"))
Dim mlen As Long
Dim i As Long
mlen = Len(str)
Exit For
If i <> 0 Then
CatTen = Trim(str)
Dim mlen As Long
Dim i As Long
mlen = Len(str)
For i = 1 To mlen
Exit For
If i <> 0 Then
CatHo = Trim(str)
Dim s As String
s = CatTen(st, "\")
s = CatHo(s, ".")
LayTF = s
Dim i As Long
Dim intCode As Long
Dim sChar As String
If sChar <> "" Then
Select Case intCode
Case 273
Case 272
Case Else
End Select
If TxtUni = "" Then
UniVba = ""
UniVba = UniVba
Sub KML_converter()
Case Is = False
'do nothing
Case Else
End Select
Dim header As Range
Dim Mau(5)
i = 0
Socot = i
i = i + 1
Loop
'MsgBox (LatOffset)
For i = 0 To 4
For j = 0 To 33
For i = 0 To Socot
Loop
Close lOutputFile
Sub t()
