Sub Export_to_Word()
Const wdCollapseEnd = 0
Dim wdapp As Object, wddoc As Object
Dim newdoc As Boolean
    Sheet1.Range("A1:H20").Copy
    Set wdapp = GetObject(, "word.Application")
    If Err.Number Then
        Err.Clear
        Set wdapp = CreateObject("Word.Application")
    wdapp.Visible = True
    Set wddoc = wdapp.documents("doc1.docx")
    If Err.Number Then
        Err.Clear
        Set wddoc = wdapp.documents.Open(ThisWorkbook.Path & "\doc1.docx")
        If Err.Number Then
            Err.Clear
            Set wddoc = wdapp.documents.Add
            wddoc.SaveAs2 ThisWorkbook.Path & "\doc1.docx"
            newdoc = True
    wddoc.Active
    If Not newdoc Then
        wddoc.Content.Select
        With wdapp.Selection
            .Collapse wdCollapseEnd
            .InsertNewPage
    wdapp.Selection.PasteSpecial xlPasteValues
    Set wddoc = Nothing
    Set wdapp = Nothing
    MsgBox "Done!"
	Thử kiểm tra kỹ code sau.
Lần chạy đầu codesẽ tạo tập tin "doc1.docx" trong cùng thư mục với tập tin Excel. Tên và vị trí của tập tin DOCX tự thay đổi cho phù hợp.
Mã:Sub Export_to_Word() Const wdCollapseEnd = 0 Dim wdapp As Object, wddoc As Object Dim newdoc As Boolean On Error Resume Next Sheet1.Range("A1:H20").Copy Set wdapp = GetObject(, "word.Application") If Err.Number Then Err.Clear Set wdapp = CreateObject("Word.Application") End If wdapp.Visible = True Set wddoc = wdapp.documents("doc1.docx") If Err.Number Then Err.Clear Set wddoc = wdapp.documents.Open(ThisWorkbook.Path & "\doc1.docx") If Err.Number Then Err.Clear Set wddoc = wdapp.documents.Add wddoc.SaveAs2 ThisWorkbook.Path & "\doc1.docx" newdoc = True End If End If wddoc.Active If Not newdoc Then wddoc.Content.Select With wdapp.Selection .Collapse wdCollapseEnd .InsertNewPage End With End If wdapp.Selection.PasteSpecial xlPasteValues Set wddoc = Nothing Set wdapp = Nothing Application.CutCopyMode = False MsgBox "Done!" End Sub
