Chào anh/chị GPE, em có câu hỏi như nêu tại tiêu đề, chi tiết cũng minh họa tại File đính kèm.
Mong các thành viên giúp.
=SUMPRODUCT(SUMIF($G$2:$G$21,$A2:$B2,$H$2:$H$21))
Sub VLooKupTheoBangTra()
Dim J As Long, Rws As Long
Dim WF As Object
Rws = [A1].CurrentRegion.Find("*", [A1], , , xlByRows, xlPrevious).Row
For J = 2 To Rws
With Cells(J, "A")
If .Value <> "" And .Offset(, 1).Value <> "" Then
.Offset(, 2).Value = WF.VLookup(.Value, Range("BTra"), 2, False) _
+ WF.VLookup(.Offset(, 1).Value, Range("BTra"), 2, False)
ElseIf .Value <> "" Then
ElseIf .Offset(, 1).Value <> "" Then
.Offset(, 2).Value = WF.VLookup(.Offset(, 1).Value, Range("BTra"), 2, False)
Next J
PHP:Option Explicit Sub VLooKupTheoBangTra() Dim J As Long, Rws As Long Dim WF As Object Rws = [A1].CurrentRegion.Find("*", [A1], , , xlByRows, xlPrevious).Row Set WF = Application.WorksheetFunction For J = 2 To Rws With Cells(J, "A") If .Value <> "" And .Offset(, 1).Value <> "" Then .Offset(, 2).Value = WF.VLookup(.Value, Range("BTra"), 2, False) _ + WF.VLookup(.Offset(, 1).Value, Range("BTra"), 2, False) ElseIf .Value <> "" Then .Offset(, 2).Value = WF.VLookup(.Value, Range("BTra"), 2, False) ElseIf .Offset(, 1).Value <> "" Then .Offset(, 2).Value = WF.VLookup(.Offset(, 1).Value, Range("BTra"), 2, False) End If End With Next J End Sub
Sub Main()
Dim rng As Range, rFind As Range, cel As Range
Dim dRes1 As Double, dRes2 As Double
With Sheets("1")
Set rng = .Range("G2:G20000")
For Each cel In .Range("C2:C20000")
If cel.Offset(, -1).Value <> Empty Or cel.Offset(, -2).Value <> Empty Then
Set rFind = rng.Find(cel.Offset(, -1).Value, , xlValues, xlWhole)
If Not rFind Is Nothing Then dRes1 = rFind.Offset(, 1).Value
Set rFind = rng.Find(cel.Offset(, -2).Value, , xlValues, xlWhole)
If Not rFind Is Nothing Then dRes2 = rFind.Offset(, 1).Value
cel.Value = dRes1 + dRes2
Sub Macro1()
Set Rng = [g1:g65000]
For Each cls In Range("a2:a" & [a65000].End(3).Row)
cls(1, 3) = Rng.Find(cls, , , 2)(1, 2) + Rng.Find(cls(1, 2), , , 2)(1, 2)
Thử cách này. Hy vọng là cột A của bạn luôn dài hơn cột BChào anh/chị GPE, em có câu hỏi như nêu tại tiêu đề, chi tiết cũng minh họa tại File đính kèm.
Sub Cong()
Dim Arr(), i, Dic As Object
Arr = Range([G2], [H65536].End(3)).Value
For i = 1 To UBound(Arr)
Dic(Arr(i, 1)) = Arr(i, 2)
Arr = Range([A2], [A65536].End(3)).Resize(, 2).Value
ReDim Preserve Arr(1 To UBound(Arr), 1 To 3)
Arr(i, 3) = Dic.Item(Arr(i, 1)) + Dic.Item(Arr(i, 2))
[A2].Resize(i - 1, 3) = Arr
Em thấy dùng Find Method là đủ rồi (tìm được ta offset qua để lấy kết quả) chứ đâu cần phải VLOOKUP hả sư phụ
Tức là Find 2 lần, lấy 2 kết quả ấy cộng lại với nhau. Kiểu vầy nè sư phụ:
Code không nhanh bằng cách dùng mảng nhưng tạm chấp nhận được cho 20000 dòng dữ liệuMã:Sub Main() Dim rng As Range, rFind As Range, cel As Range Dim dRes1 As Double, dRes2 As Double Application.ScreenUpdating = False With Sheets("1") Set rng = .Range("G2:G20000") For Each cel In .Range("C2:C20000") If cel.Offset(, -1).Value <> Empty Or cel.Offset(, -2).Value <> Empty Then Set rFind = rng.Find(cel.Offset(, -1).Value, , xlValues, xlWhole) If Not rFind Is Nothing Then dRes1 = rFind.Offset(, 1).Value Set rFind = rng.Find(cel.Offset(, -2).Value, , xlValues, xlWhole) If Not rFind Is Nothing Then dRes2 = rFind.Offset(, 1).Value cel.Value = dRes1 + dRes2 End If Next End With Application.ScreenUpdating = True End Sub
Sub DoanhThu()
Dim Rng As Range, rFind As Range, Cel As Range
With Sheets("DATA")
Set Rng = Sheets("LuyKe").Range("A2:A10000")
For Each Cel In .Range("AD7:AD10000")
If Cel.Offset(, -22).Value <> Empty Or Cel.Offset(, -20).Value <> Empty Then
Set rFind = Rng.Find(Cel.Offset(, -22).Value, , , 1)
If Not rFind Is Nothing Then dRes1 = rFind.Offset(, 2).Value
Set rFind = Rng.Find(Cel.Offset(, -20).Value, , , 1)
If Not rFind Is Nothing Then dRes2 = rFind.Offset(, 2).Value
Cel.Value = dRes1 + dRes2
