* When the spreadsheet is opened, activates the cell in
* column A of the last row that has data on every sheet.
* To take this script into use:
*  - take a backup of your spreadsheet through File > Make a copy
*  - select all the text in this script, starting at the first "/**"
*    line above, and ending at the last "}"
*  - copy the script to the clipboard with Control+C (on a Mac, ⌘C)
*  - open the spreadsheet where you want to use the function
*  - choose Extensions > Apps Script (this opens a new tab)
*  - if you see just the 'function myFunction() {}' placeholder, press
*    Control+A (on a Mac, ⌘A), followed by Control+V (⌘V) to paste
*    the script in
*  - otherwise, click Files+ > Script, enter 'Jump to last row' to name
*    the file, and press Enter, Control+A (⌘A), Control+V (⌘V)
*  - if you have an existing onOpen(e) function, add the following line
*    as the first line after the initial '{' in that onOpen(e) function:
*      jumpToLastRow();
*    ...and then delete the onOpen(e) function below
*  - press Control+S (⌘S) to save the script
*  - when prompted, name the project 'Jump to last row in every sheet'
*  - the script will run automatically when you open the spreadsheet
* Simple trigger that runs each time the user opens the spreadsheet.
* @param {Object} e The onOpen() event object.
function onOpen(e) {
  if (!e) {
    throw new Error('Please do not run the script in the script editor window. It runs automatically when you open the spreadsheet.');
  jumpToLastRow();
* Activates the first cell in the last row on every sheet.
function jumpToLastRow() {
  // version 1.0, written by --Hyde 24 August 2021
// - @see https://support.google.com/docs/thread/122596329?msgid=122680143
// - @license https://hyde.mit-license.org/2021
  const sheets = SpreadsheetApp.getActive().getSheets();
  for (let s = sheets.length - 1; s >= 0; s--) {
    sheets[s].getRange(getLastRow_(sheets[s]), 1).activate();
    SpreadsheetApp.flush();
* Gets the position of the last row that has visible content in a column of the sheet.
* When column is undefined, returns the last row that has visible content in any column.
* @param {Sheet} sheet A sheet in a spreadsheet.
* @param {Number} columnNumber Optional. The 1-indexed position of a column in the sheet.
* @return {Number} The 1-indexed row number of the last row that has visible content.
function getLastRow_(sheet, columnNumber) {
  // version 1.5, written by --Hyde, 4 April 2021
  const values = (
    columnNumber
      ? sheet.getRange(1, columnNumber, sheet.getLastRow() || 1, 1)
      : sheet.getDataRange()
  ).getDisplayValues();
  let row = values.length - 1;
  while (row && !values[row].join('')) row--;
  return row + 1;
