Các bác hướng dẫn giúp em sửa lỗi add value từ text input vào header.
Em dùng hàm UNItoVBA chuyển chuỗi nhập từ txtcongty mà nó không hiển thị ra. trong khi gán cứng thì nó lại ra. Em cám ơn.
Em gửi kèm file và code ạ.
Code đây ạ:
Private Sub btnbrowser_Click()
' Sub GettingFolder()
Dim SelectedFolder As String
With Application.FileDialog(msoFileDialogFolderPicker)
.Title = "Select folder"
.ButtonName = "Confirm"
.InitialFileName = "C:\"
If .Show = -1 Then
'ok clicked
SelectedFolder = .SelectedItems(1)
txtduongdan.Value = SelectedFolder
'MsgBox (SelectedFolder)
'cancel clicked
Private Sub btnnext_Click()
Dim chuoi, chuoimoi, congty, gdv As String
Dim i, j As Integer
'==== chuyen bien so sang format chung
chuoi = UCase(txtbks.Text)
chuoimoi = ""
For i = 1 To Len(chuoi)
If Mid(chuoi, i, 1) <> "-" And Mid(chuoi, i, 1) <> "." And Mid(chuoi, i, 1) <> "_" Then
chuoimoi = chuoimoi + Mid(chuoi, i, 1)
If Len(chuoimoi) = 8 Then
chuoimoi = Left(chuoimoi, 3) + "-" + Mid(chuoimoi, 4, 3) + "." + Right(chuoimoi, 2)
chuoimoi = Left(chuoimoi, 3) + "-" + Right(chuoimoi, 4)
congty = UNItoVBA(txtcongty.Value)
' congty = "C" & ChrW(212) & "NG TY B" & ChrW(7842) & "O HI" & ChrW(7874) & "M NGH" & ChrW(7878) & " AN"
gdv = "Gi" & ChrW(225) & "m " & ChrW(273) & ChrW(7883) & "nh vi" & ChrW(234) & "n: "
ActiveWindow.View = xlPageLayoutView
Application.PrintCommunication = False
With ActiveSheet.PageSetup
.LeftHeader = "&""Times New Roman,Bold""&12" & congty _
& Chr(10) & "&""Times New Roman,Regular""&12" & gdv _
' & Chr(10) & "&""Times New Roman,Regular""&12 Ngay giam dinh: " & "20/12/2017 BKS: "
.LeftMargin = Application.InchesToPoints(0.7)
.RightMargin = Application.InchesToPoints(0.7)
.TopMargin = Application.InchesToPoints(0.75)
.BottomMargin = Application.InchesToPoints(0.75)
.HeaderMargin = Application.InchesToPoints(0.3)
.FooterMargin = Application.InchesToPoints(0.3)
.Zoom = 100
.PrintErrors = xlPrintErrorsDisplayed
.OddAndEvenPagesHeaderFooter = False
.DifferentFirstPageHeaderFooter = False
.ScaleWithDocHeaderFooter = True
.AlignMarginsHeaderFooter = True
Application.PrintCommunication = True
Range("A1").Select
With Sheets("Data")
.Range("A3") = txtcongty.Text
.Range("A4") = txtgdv.Text
.Range("A5") = txtnggd.Text
.Range("A6") = chuoimoi
.Range("A7") = txtanhdau.Text
.Range("A8") = txtanhcuoi.Text
.Range("A9") = UNItoVBA(txtcongty.Text)
UserForm1.Hide
'Chuyen chuoi tu UNICODE sang Code VBA
Function UNItoVBA(ByVal MyStr As String) As String
Dim Str As String, i As Integer, CStart As Integer, CCount As Integer, Status As Boolean
Str = "-225-224-7843-227-7841-259-7855-7857-7859-7861-7863-226-7845-7847-7849-7851-7853-273-233-232-7867-7869-7865-234-7871-7873-7875-7877-7879-237-236-7881-297-7883-243-242-7887-245-7885-244-7889-7891-7893-7895-7897-417-7899-7901-7903-7905-7907-250-249-7911-361-7909-432-7913-7915-7917-7919-7921-253-7923-7927-7929-7925-193-192-7842-195-7840-258-7854-7856-7858-7860-7862-194-7844-7846-7848-7850-7852-272-201-200-7866-7868-7864-202-7870-7872-7874-7876-7878-205-204-7880-296-7882-211-210-7886-213-7884-212-7888-7890-7892-7894-7896-416-7898-7900-7902-7904-7906-218-217-7910-360-7908-431-7912-7914-7916-7918-7920-221-7922-7926-7928-7924-10-"
For i = 1 To Len(MyStr)
If InStr(Str, "-" & AscW(Mid(MyStr, i, 1)) & "-") = 0 Then
If Not Status Then
CStart = i: Status = True
CCount = CCount + 1
If Status Then UNItoVBA = UNItoVBA & IIf(UNItoVBA = "", "", " & ") & """" & Replace(Mid(MyStr, CStart, CCount), """", """""") & """"
Status = False
CCount = 0
UNItoVBA = UNItoVBA & IIf(UNItoVBA = "", "", " & ") & "ChrW(" & AscW(Mid(MyStr, i, 1)) & ")"
Private Sub Label1_Click()
