Hỏi cách gọi lại thư trong Mail-Outlook Express
feelingyes
Thành viên tiêu biểu
Economic
Chào các Huynh
-Em lỡ tay gởi nhầm một lá thư tới một sếp A (đáng nhé là ông B) và sếp A đang di vắng vẫn chưa đọc thư
-Em vẫn nhớ trong Outlook có tính năng gọi lại thư đã gửi (điều kiện là người nhận chưa mở thư). Nhưng tìm mãi không ra
Mong được các Huynh chỉ bảo. Thanks
Chức năng Recall message không có trong OE, nó có trong Ms Outlook.
Q:How do you recall a message that you've sent in Outlook Express? I know the option is offered in regular Outlook, but I don't see it offered in Outlook Express and can't seem to find anyone who can answer this.
A: You can't find it because it isn't there. Recalling messages -- that is, taking them back -- is an option in Outlook, but not in Outlook Express, which is a much simpler e-mail program. And even if you have Outlook, you can't recall messages unless your PC is part of a network that uses Microsoft Exchange. The recall option is primarily for use in a corporate setting where workers exchange mail with each other (and change their minds a lot, I guess).
If you are hooked up to Exchange, you can also recall a message sent across the Internet. But for that to work, the recipient must be using Outlook and must be logged on to the mail provider with Outlook open, and the message must still be in the inbox and unread. That's a lot to ask. A better solution -- don't send messages you'll regret.
The only reliable recall system I know of is America Online's, which works because AOL has a "closed" mail system that doesn't depend on the Internet. You can recall any e-mail message sent to another AOL member, as long as it hasn't been read.
Sorry Funnyboy
Mình xin cải chánh lại là "Micro-Outlook" not....Express
He he...mình không nghĩ ra, mình đọc nó trong help
1-In mail in the Navigation pane, click sent Item
2-Open message that you want to recall or replace
3-in the message window, on Action menu, click recall message
1-click vào phần thư đã gửi
2-Mở thư đã gửi của bạn
3-Ở trong của sổ của thử đã gửi-chọn thanh Action, click và "recall message"
Sorry Funnyboy
Bạn vào Sent Items, mở thư đã gửi mà muốn hủy bỏ ra, vào Message, Actions, Other Actions, chọn Recall this message, lựa tùy chọn phù hợp và OK. (Minh họa bằng Ms Outlook 2007).
